    Update auf 2.13.0
    65 Posts 4 Posters 31.6k Views 4 Watching
    • kusselinK
      kusselin
      pi@raspberrypi:~ $ pm2 stop all
      [PM2] Applying action stopProcessId on app [all](ids: 0)
      [PM2] [MagicMirror](0) ✓
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
      pi@raspberrypi:~ $ npm start
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2020-11-15T18_01_08_239Z-debug.log
        sdetweil @kusselin
        @kusselin from the MagicMirror folder
        • kusselinK
          kusselin
          username for github.com?
          what ist this?
            sdetweil @kusselin
            @kusselin the updateNotification module if u don’t use it, u can disable it.
            add
            module:"updatenotification",
            disabled: true,       // < this line
            • kusselinK
              kusselin
              the screen is always black :-(
              i ihink i have to save the config and i have to install magic mirror new…
              what do you think?
              • kusselinK
                kusselin
                after a new installation…can i also copie the save config and all is good?
                S 2 Replies Last reply
                  sdetweil @kusselin
                  @kusselin upgrade didn’t touch the config, it should be the same as before
                    sdetweil @kusselin
                    @kusselin if a NEW install, then u would have to reinstall all the modules and update the config
                    • kusselinK
                      kusselin
                      @sdetweil said in Update auf 2.13.0:
                      o.k i musst have to install all the modules again and then i can copie the config in the config folder…right?
                      And please can you send me a link how i can install about the console the ltest magic mirror please…
                      • kusselinK
                        kusselin
                        can you tell me why the screen is now black?
                          sdetweil @kusselin
                          @kusselin install is the same place u got the upgrade script
                          why are u trying to install again??
                          black screen
                          probably one of the lang files with comments
                          switch to the develop branch
                          git checkout develop
                          • kusselinK
                            kusselin
                            o.k. can you help me once again please that i have a picture…
                            pi@raspberrypi:~ $ cd MagicMirror
                            pi@raspberrypi:~/MagicMirror $ git checkout develop
                            error: Pfadspezifikation 'develop' stimmt mit keinen git-bekannten Dateien überein.
                              sdetweil @kusselin
                              @kusselin see here
                              https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
                              • kusselinK
                                kusselin
                                sorry…its not going with:
                                git fetch origin develop:develop
                                after a restart i see fast an white screen and the the black screen :-( and nothing happend
                                  sdetweil @kusselin
                                  @kusselin open the developers console, ctrl-shit-i on the mirror, or chrome from your pc if allowed,
                                  select the tab labeled ‘console’, and scroll up to see any errors…
                                  • kusselinK
                                    kusselin
                                    i can´t see a mistake…you?
                                      sdetweil @kusselin
                                      @kusselin select the tab labeled ‘console’,
                                      • kusselinK
                                        kusselin
                                        i haven´t it
                                          sdetweil @kusselin
                                          @kusselin this is ON the mirror system right?
                                          or you did
                                          address: "0.0.0.0",
                                          ipWhitelist:[],
                                          or your pi, so you can open browser from pc
                                          • kusselinK
                                            kusselin
                                            Initializing MagicMirror. main.js:487:8
                                            Loading core translation file: translations/de.json translator.js:129:9
                                            Loading core translation fallback file: translations/en.json translator.js:154:9
                                            Load script: modules/default/alert//alert.js loader.js:176:9
                                            Module registered: alert module.js:513:6
                                            Bootstrapping module: alert loader.js:148:7
                                            Load script: modules/default/alert/notificationFx.js loader.js:176:9
                                            Scripts loaded for: alert loader.js:153:8
                                            Load stylesheet: modules/default/alert/notificationFx.css loader.js:195:9
                                            Load stylesheet: vendor/css/font-awesome.css loader.js:195:9
                                            Styles loaded for: alert loader.js:155:9
                                            alert - Load translation: translations/de.json translator.js:100:9
                                            alert - Load translation fallback: translations/en.json translator.js:102:9
                                            Translations loaded for: alert loader.js:157:10
                                            Load script: modules/default/updatenotification//updatenotification.js loader.js:176:9
                                            Module registered: updatenotification module.js:513:6
                                            Bootstrapping module: updatenotification loader.js:148:7
                                            Scripts loaded for: updatenotification loader.js:153:8
                                            Styles loaded for: updatenotification loader.js:155:9
                                            Translations loaded for: updatenotification loader.js:157:10
                                            Load script: modules/default/clock//clock.js loader.js:176:9
                                            Module registered: clock module.js:513:6
                                            Bootstrapping module: clock loader.js:148:7
                                            Load script: vendor/node_modules/moment/min/moment-with-locales.js loader.js:176:9
                                            Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js loader.js:176:9
                                            Load script: vendor/node_modules/suncalc/suncalc.js loader.js:176:9
                                            Scripts loaded for: clock loader.js:153:8
                                            Load stylesheet: modules/default/clock/clock_styles.css loader.js:195:9
                                            Styles loaded for: clock loader.js:155:9
                                            Translations loaded for: clock loader.js:157:10
                                            Load script: modules/default/calendar//calendar.js loader.js:176:9
                                            Module registered: calendar module.js:513:6
                                            Bootstrapping module: calendar loader.js:148:7
                                            File already loaded: moment.js loader.js:236:9
                                            Scripts loaded for: calendar loader.js:153:8
                                            Load stylesheet: modules/default/calendar/calendar.css loader.js:195:9
                                            File already loaded: font-awesome.css loader.js:236:9
                                            Styles loaded for: calendar loader.js:155:9
                                            Translations loaded for: calendar loader.js:157:10
                                            File already loaded: calendar.css loader.js:236:9
                                            Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js loader.js:176:9
                                            Module registered: MMM-OpenmapWeather module.js:513:6
                                            Bootstrapping module: MMM-OpenmapWeather loader.js:148:7
                                            Scripts loaded for: MMM-OpenmapWeather loader.js:153:8
                                            Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css loader.js:195:9
                                            Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css loader.js:195:9
                                            Styles loaded for: MMM-OpenmapWeather loader.js:155:9
                                            Translations loaded for: MMM-OpenmapWeather loader.js:157:10
                                            Load script: modules/default/weatherforecast//weatherforecast.js loader.js:176:9
                                            Module registered: weatherforecast module.js:513:6
                                            Bootstrapping module: weatherforecast loader.js:148:7
                                            Scripts loaded for: weatherforecast loader.js:153:8
                                            File already loaded: weather-icons.css loader.js:236:9
                                            Load stylesheet: modules/default/weatherforecast/weatherforecast.css loader.js:195:9
                                            Styles loaded for: weatherforecast loader.js:155:9
                                            Translations loaded for: weatherforecast loader.js:157:10
                                            Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js loader.js:176:9
                                            Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.4.0 - Current version: 2.13.0 module.js:505:7
                                            Version is ok! module.js:507:8
                                            Module registered: MMM-Remote-Control module.js:513:6
                                            Bootstrapping module: MMM-Remote-Control loader.js:148:7
                                            Scripts loaded for: MMM-Remote-Control loader.js:153:8
                                            Load stylesheet: modules/MMM-Remote-Control/remote-control.css loader.js:195:9
                                            Styles loaded for: MMM-Remote-Control loader.js:155:9
                                            Translations loaded for: MMM-Remote-Control loader.js:157:10
                                            Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js loader.js:176:9
                                            Module registered: MMM-SoccerLiveScore module.js:513:6
                                            Bootstrapping module: MMM-SoccerLiveScore loader.js:148:7
                                            Scripts loaded for: MMM-SoccerLiveScore loader.js:153:8
                                            Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css loader.js:195:9
                                            Styles loaded for: MMM-SoccerLiveScore loader.js:155:9
                                            Translations loaded for: MMM-SoccerLiveScore loader.js:157:10
                                            Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js loader.js:176:9
                                            Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.13.0 module.js:505:7
                                            Module registered: MMM-Tankerkoenig module.js:513:6
                                            Bootstrapping module: MMM-Tankerkoenig loader.js:148:7
                                            Scripts loaded for: MMM-Tankerkoenig loader.js:153:8
                                            Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css loader.js:195:9
                                            Styles loaded for: MMM-Tankerkoenig loader.js:155:9
                                            MMM-Tankerkoenig - Load translation: i18n/de.json translator.js:100:9
                                            MMM-Tankerkoenig - Load translation fallback: i18n/en.json translator.js:102:9
                                            Translations loaded for: MMM-Tankerkoenig loader.js:157:10
                                            Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js loader.js:176:9
                                            Module registered: MMM-SmartWebDisplay module.js:513:6
                                            Bootstrapping module: MMM-SmartWebDisplay loader.js:148:7
                                            Scripts loaded for: MMM-SmartWebDisplay loader.js:153:8
                                            Load stylesheet: modules/MMM-SmartWebDisplay/MMM-SmartWebDisplay.css loader.js:195:9
                                            Styles loaded for: MMM-SmartWebDisplay loader.js:155:9
                                            Translations loaded for: MMM-SmartWebDisplay loader.js:157:10
                                            Load script: modules/MMM-ioBroker//MMM-ioBroker.js loader.js:176:9
                                            Module registered: MMM-ioBroker module.js:513:6
                                            Bootstrapping module: MMM-ioBroker loader.js:148:7
                                            Scripts loaded for: MMM-ioBroker loader.js:153:8
                                            Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css loader.js:195:9
                                            Styles loaded for: MMM-ioBroker loader.js:155:9
                                            Translations loaded for: MMM-ioBroker loader.js:157:10
                                            Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js loader.js:176:9
                                            Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0 module.js:505:7
                                            Module registered: MMM-FRITZ-Box-Callmonitor module.js:513:6
                                            Bootstrapping module: MMM-FRITZ-Box-Callmonitor loader.js:148:7
                                            Scripts loaded for: MMM-FRITZ-Box-Callmonitor loader.js:153:8
                                            Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css loader.js:195:9
                                            Styles loaded for: MMM-FRITZ-Box-Callmonitor loader.js:155:9
                                            MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json translator.js:100:9
                                            Uncaught SyntaxError: JSON.parse: expected double-quoted property name at line 5 column 3 of the JSON data
                                                onreadystatechange http://192.168.200.151:8080/js/translator.js:22
                                            translator.js:22:19
                                            • 3 / 4
