    Update auf 2.13.0
    65 Posts 4 Posters 31.6k Views 4 Watching
      sdetweil @kusselin
      @kusselin looks like u might have changed compliments.js for some reason…
      unless u applied a fix, you should never change the code in the module folders…
      (else u run into this problem)…
      I would say no, and figure out what needs to be saved and then restart it…
      (this is test mode, so we are not changing anything)
      • kusselinK
        kusselin
        @sdetweil said in Update auf 2.13.0:
        o.k. look:
        pi@raspberrypi:~/MagicMirror $ rm -rf .git/refs/tags/v2.12.0
        pi@raspberrypi:~/MagicMirror $ git prune
        Prüfe Konnektivität: 16017, Fertig.
        pi@raspberrypi:~/MagicMirror $ git gc
        Objekte aufzählen: 16017, Fertig.
        Zähle Objekte: 100% (16017/16017), Fertig.
        Delta-Kompression verwendet bis zu 4 Threads.
        Komprimiere Objekte: 100% (5873/5873), Fertig.
        Schreibe Objekte: 100% (16017/16017), Fertig.
        Gesamt 16017 (Delta 9849), Wiederverwendet 15910 (Delta 9746)
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        No LSB modules are available.
        saving custom.css
        upgrading from version 2.9.0 to 2.13.0
        fetching latest revisions
        From https://github.com/MichMich/MagicMirror
         * [new tag]         v2.12.0    -> v2.12.0
        there are 2 local files that are different than the master repo
           modules/default/compliments/compliments.js
           package-lock.json
        any *-lock.json files do not need to be saved
        do you want to save these files for later   (Y/n)?n
        skipping restore for modules/default/compliments/compliments.js, doing test run
        skipping restore for package-lock.json, doing test run
        processing for module MMM-Remote-Control please wait
        skipped processing for MMM-Remote-Control, doing test run
        processing complete for module MMM-Remote-Control
        processing for module MMM-SoccerLiveScore please wait
        skipped processing for MMM-SoccerLiveScore, doing test run
        processing complete for module MMM-SoccerLiveScore
        processing for module MMM-SmartWebDisplay please wait
        skipped processing for MMM-SmartWebDisplay, doing test run
        processing complete for module MMM-SmartWebDisplay
        processing for module MMM-ioBroker please wait
        skipped processing for MMM-ioBroker, doing test run
        processing complete for module MMM-ioBroker
        processing for module MMM-FRITZ-Box-Callmonitor please wait
        skipped processing for MMM-FRITZ-Box-Callmonitor, doing test run
        processing complete for module MMM-FRITZ-Box-Callmonitor
        processing for module MMM-Fuel please wait
        skipped processing for MMM-Fuel, doing test run
        processing complete for module MMM-Fuel
        processing for module MMM-PublicTransportHafas please wait
        skipped processing for MMM-PublicTransportHafas, doing test run
        processing complete for module MMM-PublicTransportHafas
        processing for module MMM-Tools please wait
        skipped processing for MMM-Tools, doing test run
        processing complete for module MMM-Tools
        restoring custom.css
        saving custom.css
           package-lock.json
        it look good so or?
          sdetweil @kusselin
          @kusselin well, you still need to resolve the problem with compliments.js…
          if u don’t save it, then u lose whatever changes u made (but it might not matter)
          if u DO save it, (and restore it) then it might not work anymore, or cause problems…
          the test run warns that there WILL be a problem u need to fix first… (or understand how to resolve later)
          • kusselinK
            kusselin
            o.k. but one question…must i update my magic mirror? now it runs good…an i know there is a statement:
            “NEVER CHANGE A RUNNING SYSTEM”
            what you say?
              sdetweil @kusselin
              @kusselin you do NOT HAVE to update, unless u have a problem , or unless u need a new feature…
              • kusselinK
                kusselin
                i risk it … with “SAVE” now …pleas wait while updating… i will get back to you soon
                How long does the update while?
                  sdetweil @kusselin
                  @kusselin maybe 30 minutes
                  • kusselinK
                    kusselin
                    ui …ok. thats a house number…
                    i will back then
                    for you first thanks a lot :-)
                    • kusselinK
                      kusselin
                      look…can you say something about this installation now?
                      pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubuserconten        t.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                      doing test run = false
                      saving custom.css
                         package-lock.json
                      do you want to save these files for later   (Y/n)?Y
                      > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stam        p
                      > node ./msg.js
                      Attention
                          Console-stamp version 3.0.0 Release Candidate is out. Install by using the t        ag '@next'. NB: Breaking changes.
                          For more details goto: https://www.npmjs.com/package/console-stamp/v/next
                      > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      Downloading tmp-16303-1-SHASUMS256.txt-6.1.12
                      [============================================>] 100.0% of 5.62 kB (5.62 kB/s)
                      > magicmirror@2.13.0 install /home/pi/MagicMirror
                      " && cd vendor && npm install --loglevel=error
                      added 3 packages from 3 contributors, removed 62 packages, updated 17 packages and audited 24 packages in 38.077s
                      1 package is looking for funding
                        run `npm fund` for details
                      found 0 vulnerabilities
                      > magicmirror@2.13.0 postinstall /home/pi/MagicMirror
                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                      > magicmirror@2.13.0 install-fonts /home/pi/MagicMirror
                      > echo "Installing fonts ...
                      " && cd fonts && npm install --loglevel=error
                      updated 1 package and audited 1 package in 8.1s
                      added 81 packages from 60 contributors, removed 340 packages, updated 119 packages and audited 1164 packages in 928.05s
                      9 packages are looking for funding
                      found 3 low severity vulnerabilities
                        run `npm audit fix` to fix them, or `npm audit` for details
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      added 30 packages from 24 contributors and audited 30 packages in 22.948s
                      up to date in 2.55s
                      added 93 packages from 86 contributors and audited 94 packages in 49.515s
                      added 41 packages from 465 contributors and audited 41 packages in 32.545s
                      2 packages are looking for funding
                      found 1 low severity vulnerability
                      added 11 packages from 64 contributors and audited 11 packages in 15.02s
                      npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                      npm WARN eslint-config-recommended@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN eslint-config-esnext@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN eslint-config-node@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN eslint-config-react-native@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                      added 584 packages from 375 contributors and audited 584 packages in 366.594s
                      38 packages are looking for funding
                      added 33 packages from 23 contributors and audited 33 packages in 25.836s
                      added 3 packages from 3 contributors and audited 3 packages in 8.165s
                      we stashed a set of files that appear changed from the latest repo versions. you should review them
                      see installers/stashed_files for the list
                      you can use git checkout stash@{0} -- filename to extract one file from the stash
                      or git stash pop to restore them all
                      WARNING..
                      WARNING.. either will overlay the file just installed by the update
                      WARNING..
                        sdetweil @kusselin
                        @kusselin cool… looks good… now to run MM… and see if it all works…
                        • kusselinK
                          kusselin
                          no, nothing is good…sorry:
                          i have a black screen :-(
                          > magicmirror@2.13.0 start /home/pi/MagicMirror
                          > ./run-start.sh $1
                          [2020-11-15 18:39:25.557] [LOG]    Starting MagicMirror: v2.13.0
                          [2020-11-15 18:39:25.648] [LOG]    Loading config ...
                          [2020-11-15 18:39:25.691] [LOG]    Loading module helpers ...
                          [2020-11-15 18:39:25.703] [LOG]    No helper found for module: alert.
                          [2020-11-15 18:39:26.107] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:26.112] [LOG]    Module helper loaded: updatenotification
                          [2020-11-15 18:39:26.117] [LOG]    No helper found for module: clock.
                          [2020-11-15 18:39:30.439] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:30.444] [LOG]    Module helper loaded: calendar
                          [2020-11-15 18:39:30.451] [LOG]    No helper found for module: MMM-OpenmapWeather.
                          [2020-11-15 18:39:30.457] [LOG]    No helper found for module: weatherforecast.
                          [2020-11-15 18:39:31.996] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:32.001] [LOG]    Module helper loaded: MMM-Remote-Control
                          [2020-11-15 18:39:32.030] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:32.039] [LOG]    Module helper loaded: MMM-SoccerLiveScore
                          [2020-11-15 18:39:32.059] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:32.062] [LOG]    Module helper loaded: MMM-Tankerkoenig
                          [2020-11-15 18:39:32.069] [LOG]    No helper found for module: MMM-SmartWebDisplay.
                          [2020-11-15 18:39:32.099] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:32.107] [LOG]    Module helper loaded: MMM-ioBroker
                          [2020-11-15 18:39:33.022] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:33.024] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
                          [2020-11-15 18:39:33.475] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:33.482] [LOG]    Module helper loaded: MMM-Fuel
                          [2020-11-15 18:39:34.691] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:34.693] [LOG]    Module helper loaded: MMM-PublicTransportHafas
                          [2020-11-15 18:39:34.696] [LOG]    No helper found for module: compliments.
                          [2020-11-15 18:39:35.002] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:35.010] [LOG]    Module helper loaded: MMM-Tools
                          [2020-11-15 18:39:35.216] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:35.222] [LOG]    Module helper loaded: newsfeed
                          [2020-11-15 18:39:35.239] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:35.245] [LOG]    Module helper loaded: MMM-COVID19
                          [2020-11-15 18:39:35.264] [LOG]    Initializing new module helper ...
                          [2020-11-15 18:39:35.270] [LOG]    Module helper loaded: MMM-COVID19-AMPEL
                          [2020-11-15 18:39:35.275] [LOG]    All module helpers loaded.
                          [2020-11-15 18:39:36.247] [LOG]    Starting server on port 8080 ...
                          [2020-11-15 18:39:36.295] [INFO]   You're using a full whitelist configuration to allow for all IPs
                          [2020-11-15 18:39:36.338] [LOG]    Server started ...
                          [2020-11-15 18:39:36.347] [LOG]    Connecting socket for: updatenotification
                          [2020-11-15 18:39:36.355] [LOG]    Connecting socket for: calendar
                          [2020-11-15 18:39:36.359] [LOG]    Starting node helper for: calendar
                          [2020-11-15 18:39:36.363] [LOG]    Connecting socket for: MMM-Remote-Control
                          [2020-11-15 18:39:36.370] [LOG]    Starting node helper for: MMM-Remote-Control
                          [2020-11-15 18:39:36.418] [LOG]    Connecting socket for: MMM-SoccerLiveScore
                          [2020-11-15 18:39:36.424] [LOG]    MMM-SoccerLiveScore helper started...
                          [2020-11-15 18:39:36.427] [LOG]    Connecting socket for: MMM-Tankerkoenig
                          [2020-11-15 18:39:36.430] [LOG]    Starting module helper: MMM-Tankerkoenig
                          [2020-11-15 18:39:36.435] [LOG]    Connecting socket for: MMM-ioBroker
                          [2020-11-15 18:39:36.441] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
                          [2020-11-15 18:39:36.446] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
                          [2020-11-15 18:39:36.451] [LOG]    Connecting socket for: MMM-Fuel
                          [2020-11-15 18:39:36.456] [LOG]    Starting module helper: MMM-Fuel
                          [2020-11-15 18:39:36.459] [LOG]    Connecting socket for: MMM-PublicTransportHafas
                          [2020-11-15 18:39:36.462] [LOG]    Connecting socket for: MMM-Tools
                          [2020-11-15 18:39:36.468] [LOG]    [Tools] MMM-Tools Version: 2.0.3
                          [2020-11-15 18:39:36.472] [LOG]    Connecting socket for: newsfeed
                          [2020-11-15 18:39:36.476] [LOG]    Starting node helper for: newsfeed
                          [2020-11-15 18:39:36.480] [LOG]    Connecting socket for: MMM-COVID19
                          [2020-11-15 18:39:36.484] [LOG]    Starting node helper for: MMM-COVID19
                          [2020-11-15 18:39:36.489] [LOG]    Connecting socket for: MMM-COVID19-AMPEL
                          [2020-11-15 18:39:36.492] [LOG]    Starting node helper for: MMM-COVID19-AMPEL
                          [2020-11-15 18:39:36.494] [LOG]    Sockets connected & modules started ...
                          [2020-11-15 18:39:36.538] [ERROR]  Whoops! There was an uncaught exception...
                          [2020-11-15 18:39:36.543] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                              at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                              at listenInCluster (net.js:1274:12)
                              at doListen (net.js:1413:7)
                              at processTicksAndRejections (internal/process/task_queues.js:84:9) {
                            code: 'EADDRINUSE',
                            errno: 'EADDRINUSE',
                            syscall: 'listen',
                            address: '0.0.0.0',
                            port: 8080
                          [2020-11-15 18:39:36.573] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2020-11-15 18:39:36.576] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [2020-11-15 18:39:38.359] [LOG]    Launching application.
                          Username for 'https://github.com':
                            sdetweil @kusselin
                            @kusselin said in Update auf 2.13.0:
                            mirror already running…
                            can’t run two at the same time… (on the same port)
                            • kusselinK
                              kusselin
                              o.k. and what can i do now…?
                              Sorry for my questions but i´m not the expert as you
                                sdetweil @kusselin
                                @kusselin if you use pm2 to start a boot,
                                pm2 stop all
                                then npm start to test
                                • kusselinK
                                  kusselin
                                  pi@raspberrypi:~ $ pm2 stop all
                                  [PM2] Applying action stopProcessId on app [all](ids: 0)
                                  [PM2] [MagicMirror](0) ✓
                                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                  │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                  pi@raspberrypi:~ $ npm start
                                  npm ERR! code ENOENT
                                  npm ERR! syscall open
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                  npm ERR! enoent This is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR!     /home/pi/.npm/_logs/2020-11-15T18_01_08_239Z-debug.log
                                    sdetweil @kusselin
                                    @kusselin from the MagicMirror folder
                                    • kusselinK
                                      kusselin
                                      username for github.com?
                                      what ist this?
                                        sdetweil @kusselin
                                        @kusselin the updateNotification module if u don’t use it, u can disable it.
                                        add
                                        module:"updatenotification",
                                        disabled: true,       // < this line
                                        • kusselinK
                                          kusselin
                                          the screen is always black :-(
                                          i ihink i have to save the config and i have to install magic mirror new…
                                          what do you think?
                                          • kusselinK
                                            kusselin
                                            after a new installation…can i also copie the save config and all is good?
                                            S 2 Replies Last reply
                                            • 2 / 4
