    Black screen
    7 Posts 3 Posters 1.5k Views 3 Watching
      r3zi3lr
      I’ve managed to install the Module but I’m getting just a black screen for the module.
      Have I forgotten to install something?
      Code for my config.js below:
      module: "MMM-TomTomTrafficIncidents",
      			position: "center",
      			key: "",
      			lng: -123.1139529,
      			lat:  49.2608724,
      			zoom: 11,
      			height: "500px",
      			width: "800px"
      Thank you.
        sdetweil @r3zi3lr
        @r3zi3lr said in Black screen:
        open the developers window, ctrl-shift-i on the keyboard, select the tab labled ‘console’ and scroll up to see any errors… u can also filter by module, by placing some part of the module name in the filter field, like ‘tom’
        please use code block markers for config items… select the text, and push the </> button above the editor
        R 2 Replies Last reply Reply Quote 0
          r3zi3lr @sdetweil
          Thank you for the quick response.
          I got this:
          loader.js:182 Load script: modules/default/alert/modernizr.custom.js
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure protocols. This exposes users of this app to unnecessary security risks. Consider loading the following resources over HTTPS or FTPS.
          • http://localhost:8080/css/main.css
          • http://localhost:8080/fonts/roboto.css
          • http://localhost:8080/socket.io/socket.io.js
          • http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          • http://localhost:8080/js/defaults.js
          • http://localhost:8080/config/config.js
          • http://localhost:8080/vendor/vendor.js
          • http://localhost:8080/modules/default/defaultmodules.js
          • http://localhost:8080/js/logger.js
          • http://localhost:8080/translations/translations.js
          • http://localhost:8080/js/translator.js
          • http://localhost:8080/js/class.js
          • http://localhost:8080/js/module.js
          • http://localhost:8080/js/loader.js
          • http://localhost:8080/js/socketclient.js
          • http://localhost:8080/js/main.js
          • http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          • http://localhost:8080/translations/en.json
          • http://localhost:8080/modules/default/alert//alert.js
          • http://localhost:8080/modules/default/alert/classie.js
          • http://localhost:8080/modules/default/alert/modernizr.custom.js
          • http://localhost:8080/modules/default/alert/notificationFx.js
          • http://localhost:8080/modules/default/alert/ns-default.css
          For more information and help, consult https://electronjs.org/docs/tutorial/security.
          This warning will not show up once the app is packaged.
          warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128
          loader.js:182 Load script: modules/MMM-TomTomTrafficIncidents//MMM-TomTomTrafficIncidents.js
          module.js:477 Module registered: MMM-TomTomTrafficIncidents
          loader.js:152 Bootstrapping module: MMM-TomTomTrafficIncidents
          loader.js:157 Scripts loaded for: MMM-TomTomTrafficIncidents
          loader.js:197 Load stylesheet: modules/MMM-TomTomTrafficIncidents/tomtom-international-web-sdk-maps/maps.css
          loader.js:197 Load stylesheet: modules/MMM-TomTomTrafficIncidents/tomtom-international-web-sdk-maps/traffic-incidents.css
          loader.js:159 Styles loaded for: MMM-TomTomTrafficIncidents
          loader.js:161 Translations loaded for: MMM-TomTomTrafficIncidents
          loader.js:197 Load stylesheet: css/custom.css
          MMM-TomTomTrafficIncidents.js:35 Starting module: MMM-TomTomTrafficIncidents
          MMM-TomTomTrafficIncidents.js:44 MMM-TomTomTrafficIncidents: Using JS & CSS from local source.
          module.js:156 MMM-TomTomTrafficIncidents received a system notification: ALL_MODULES_STARTED
          module.js:156 MMM-TomTomTrafficIncidents received a system notification: MODULE_DOM_CREATED
          module.js:156 MMM-TomTomTrafficIncidents received a system notification: DOM_OBJECTS_CREATED
          module.js:154 MMM-TomTomTrafficIncidents received a module notification: CURRENTWEATHER_DATA from sender: currentweather
          maps-web.min.js:1 Error: Failed to initialize WebGL
          at A._setupPainter (maps-web.min.js:1)
          at new A (maps-web.min.js:1)
          at e.mapboxMapFactory (maps-web.min.js:1)
          at t.createMap (maps-web.min.js:1)
          at new map (maps-web.min.js:1)
          at HTMLScriptElement.script.onload (MMM-TomTomTrafficIncidents.js:70)
          wt.fire @ maps-web.min.js:1
          maps-web.min.js:1 Uncaught Error: Failed to initialize WebGL.
          module.js:154 MMM-TomTomTrafficIncidents received a module notification: CALENDAR_EVENTS from sender: calendar
            sdetweil @r3zi3lr
            to test do this
            cd ~/MagicMirror
            node node_modules/.bin/electron https://webglreport.com/?v=1
            it may be a hardware config issue for the display driver (I don’t know how to fix it myself), google may help, other users too…
              r3zi3lr @sdetweil
              Managed to fix it myself using the below:
              Console: sudo raspi-config Under “7 Advanced Options” / “A7 GL Driver” pick “G2 GL (Fake KMS)”
              Desktop: Preferences / Add Remove Software search for “Chrome” and pick “WebDriver driver for the Chromium Browser”, click “OK”
              S 1 Reply Last reply Reply Quote 2
                sdetweil @r3zi3lr
                @r3zi3lr awesome!
                • TravelbaconT Offline
                  Travelbacon
                  Nice work. I will also add in my documentation that Fake KMS must be set. :)
                  Btw: Did you check the Pi settings on:
                  https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi ?
                  There might be a change that you can have other options.
                  @MichMich The FAQ seems to be outdated. In the newest Raspberry Pi OS (Raspbian) the whole raspi-config has changed for the driver settings.
