    Nubie question... How do I kill magic mirror so that I test new settings for config.js
    4 Posts 2 Posters 5.0k Views 2 Watching
    • R
      RudyRipDraw
      Re: Complete remote administration using SSH
      • M
        mochman Module Developer
        If you’re using pm2 then SSH in and run
        pm2 stop mm
        If you’re using the nohup command to run it, you’ll have to find the PID by running
        ps aux | grep npm
        You should see something like
        pi 26292 38.3 4.3 122360 38428 pts/0 Sl 19:17 0:03 npm
        pi 26318 0.0 0.2 4276 1952 pts/0 S+ 19:18 0:00 grep --color=auto npm
        use the first number you see in the line that just has “npm” (in this example it’s 26292)
        then run
        kill 26292 (using your PID number)
        I recommend setting up pm2. It makes it much easier.
        • R
          RudyRipDraw
          thanks, will look into pm2.
          Also it turns out that if I run “DISPLAY=:0 npm start” from a ssh terminal, magic mirror shows up on the HDMI display. When I control-c on the ssh terminal, it stops the magic mirror.
          • M
            Right, the nohup command removes the process from the terminal window. If you shut down the terminal, it’ll also shut down your magic mirror without the nohup command before npm.
