    MMM-Carousel w/ Slide Navigation
    15 Posts 2 Posters 5.3k Views 3 Watching
      raf
      why can’t I switch my pages manually
      no arrows are displayed on the screen
      the page indicators are displayed
      I can move the mouse anywhere on the screen but no arrows
      this is in my config.js
                  module: 'MMM-Carousel',
                  position: 'bottom_bar', // Required only for navigation controls
                      transitionInterval: 0,
                      ignoreModules: ['clock', 'alert'],
                      mode: 'slides',
                      showPageIndicators: true,
                      showPageControls: true,
                      slides: {
                          main: ['calendar', 'currentweather', 'MMM-Tools', 'newsfeed', 'MMM-TuyaSL', 'MMM-NowPlayingOnSpotify', 'weatherforecast',],
                          "Slide 2": ['newsfeed',],
                      keyBindings: {
                          enabled: true,
                          map: {
                              NextSlide: "ArrowRight",
                              PrevSlide: "ArrowLeft",
                              Slide0:    "Home"
                          mode: "DEFAULT"```
      code_text
      code_text
        banbutcher
        hey buddy,
        take a look at the way each slide is defined! think your missing quotes from main page
        • at bottom not sure but i think mode should be keyBindingsMode
        • missing a comma after slide0
        • not sure but check that all your open { have a closer }
        • do you have MMM-Keybindings installed? (eidt - i just checked and carousel wont change pages without MMM-Keybindings.)
                        ignoreModules: ['alert', 'MMM-GoogleAssistant'],
                        mode: 'slides',
                        slides: {
                            "Default":['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast', 'MMM-Weather'],
                            "Work":['MMM-google-route'],
                            "Office":['MMM-google-route2'],
        //		    "Traffic":['MMM-GoogleMapsTraffic'],
                            "Home":['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
        		    'MMM-COVID19-SPARKLINE', 'MMM-Spotify', 'MMM-GoogleFit', 'MMM-Todoist', 'newsfeed'],
                            "Info":['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-Tools', 'MMM-NetworkScanner',
        		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats'],
                        keyBindings: {
                            enabled: true,
                            map: {
                                Slide0: "ArrowUp",
        			Slide5: "ArrowDown",
                            keyBindingsMode: "DEFAULT"
        here is my config for MMM-Keybindings:
        /*-------------------- MMM-KeyBindings Start-----------------*/
            module: 'MMM-KeyBindings',
        	evdev: {enabled: false},
                enableKeyboard: true,
        	actions: [
        	  key: "ArrowRight",
        	  state: "KEY_PRESSED",
        	  instance: "SERVER",
        	  mode: "DEFAULT",
        	 key: "ArrowLeft",
        	 instance: "SERVER",
        	 mode: "DEFAULT",
        have a look at my working code and try again! :)
          raf @banbutcher
          @banbutcher
                          ignoreModules: ['clock', 'alert', 'MMM-GoogleAssistant',],
                          mode: 'slides',
                          slides: {
                              "Default": ['calendar', 'currentweather', 'MMM-Tools', 'newsfeed', 'MMM-TuyaSL', 'MMM-NowPlayingOnSpotify', 'weatherforecast',],
                              "Slide 3": ['newsfeed',],
                              "Slide 4": ['newsfeed',],
                              "Slide 5": ['newsfeed',],
                          keyBindings: {
                              enabled: true,
                              map: {
                                  Slide0: "ArrowUp",
                              mode: "DEFAULT"
                  	actions: [
                  	  key: "ArrowRight",
                  	  instance: "SERVER",
                  	  mode: "DEFAULT",
                  	 key: "ArrowLeft",
                  	 instance: "SERVER",
                  	 mode: "DEFAULT",
          it still doesn’t work and I don’t see what’s wrong (I have to tell you that I control the pi via my windows pc) with vnc
            banbutcher
            @raf the only thing i can think of is to rename the slides without numbers, you dont need them for the keybindings, it sets it automatically:
            "default" = slide0, "slide 2" = slide1 etc…
            try renaming the slides maybe "zero" "one" "two" etc…
            also check whos version of carousel you have as theres 2! :dizzy_face:
            look over this, its how i figured it out!! :thumbs_up_light_skin_tone:
            i use vnc from a mac so should be ok!?
              raf @banbutcher
              @banbutcher
              have given the pages a different name, but that is not the solution
                banbutcher
                Did you see which version on carousel you have?
                  raf @banbutcher
                  @banbutcher
                  carousel version 0.2.6
                  keyBindings 1.3.1
                    raf
                    I have seen at startup it does give a message: (No helper found for module: MMM-Carousel.)
                    but i don’t know if it is normal and what i can do about it
                    [2020-11-03 11:17:14.590] [LOG]    Starting MagicMirror: v2.13.0
                    [2020-11-03 11:17:14.606] [LOG]    Loading config ...
                    [2020-11-03 11:17:14.621] [LOG]    Loading module helpers ...
                    [2020-11-03 11:17:14.624] [LOG]    No helper found for module: MMM-Carousel.
                    [2020-11-03 11:17:14.639] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:14.642] [LOG]    Module helper loaded: MMM-KeyBindings
                    [2020-11-03 11:17:15.562] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:15.563] [LOG]    Module helper loaded: MMM-UpdateNotification
                    [2020-11-03 11:17:21.615] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:21.617] [LOG]    Module helper loaded: MMM-GoogleAssistant
                    [2020-11-03 11:17:24.351] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:24.353] [LOG]    Module helper loaded: MMM-Assistant2Display
                    [2020-11-03 11:17:24.355] [LOG]    No helper found for module: alert.
                    [2020-11-03 11:17:24.362] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:24.364] [LOG]    Module helper loaded: updatenotification
                    [2020-11-03 11:17:24.366] [LOG]    No helper found for module: clock.
                    [2020-11-03 11:17:25.219] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:25.221] [LOG]    Module helper loaded: calendar
                    [2020-11-03 11:17:25.374] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:25.375] [LOG]    Module helper loaded: MMM-Tools
                    [2020-11-03 11:17:25.511] [LOG]    Initializing new module helper ...
                    [2020-11-03 11:17:25.512] [LOG]    Module helper loaded: MMM-TuyaSL
                      banbutcher
                      just checked about the node helper and that comes up on mine too! :)
                      as for version - i mean whos git repo did you clone from, as you would have read if you read the link i gave you >:( that there are at least 2 versions of carousel. go to the module folder and check the readme file and it will be in there some where…
                      use the link above and read it! solution should be there!
                        raf @banbutcher
                        @banbutcher
                        barnabycolby & shbatm
                        the carousel works over SSH, right?
                          banbutcher @raf
                          @raf
                          if its not working after that, im afraid i dont know, sorry
                          i dont know anything about ssh either :(
                            raf
                            @vondes
                            have been on it for days even now at the moment and still nothing
                              raf
                              in the end this is my solution (don’t add keybindings)
                                              mode: 'slides',
                                              slides: {
                                              keyBindings: {
                                                  enabled: true,
                                                  map: {
                                                      Slide0: "ArrowUp",
                                                  mode: "DEFAULT"
                                banbutcher
                                glad to hear you figured it out, i know coming from a very limited knowledge base, trial and error was how i figured it out!
                                when you say dont add key bindings do you mean the module MMM-Keybindings or the keyBindings in the carousel config?
                                  raf @banbutcher
                                  @banbutcher
                                  module installed (MMM-Keybindings) but not added in the config and it works (my knowledge is also very limited because I also have to figure everything out) I normally work in the concrete so that is something completely different huh
