    Unexpected Token, config not working
    4 Posts 3 Posters 1.8k Views 3 Watching
      jwest35
      I am new to all this and been trying to get the look and feel that I want. I found some code online to help me with it, however I keep getting a syntax error, unexpected token
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      port: 8080,
      basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      useHttps: false, // Support HTTPS or not, default "false" will use HTTP
      httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true
      httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true
      language: "en",
      logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      timeFormat: 24,
      units: "imperial",
      module: "alert",
      module: "updatenotification",
      position: "top_bar"
      module: "clock",
      position: "top_left"
      module: "currentweather",
      locationID: "4106458", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      appid: "dfa44a36596bdb042674a5e3058849c7"
      module: "weatherforecast",
      header: "Weather Forecast",
      header: "US Holidays",
      symbol: "calendar-check",
      url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" }
                              module: "MMM-CalendarExt2",
                                          url: "https://mycalendar"
                                  views: [
                                        title: "Upcoming Events",
                                        mode: "daily",
                                        calendars: [],
                                        position:"top_left",
                                        hideOverflow: false,
                                        slotCount: 3,
                                        className: "remove_empty_slot"
                                      mode: "month",
                                      position: "fullscreen_below",
                                      timeFormat: "h:mm",
                                      slotMaxHeight: "200px",
                                      maxItems: 500,
                                  scenes: [
      ******************CSS*****************
      body {
              margin: 10px;
      /*      height: calc(100%);*/
              width: 1060px;
      .CX2 .remove_empty_slot .eventCount_0 {
        display:none;
      .CX2 .cellSlot .slotSubTitle {
      color:#3A6061;
      .CX2 .cellSlot .slotTitle {
      color:#999;
      text-alignment: "right";
      .CX2 .cellSlot.weekday_6 .slotSubTitle {
      color:#3A6061;
      .CX2 .cellSlot.weekday_6 .slotTitle {
      color:#999;
      .CX2 .cellSlot.weekday_7 .slotSubTitle {
      color:#661414;
      .CX2 .slot{
      padding:0px 4px;
      border:4px solid #000000;
      /* Formats header */
      .CX2 .slot .slotHeader {
      background-color:#000000;
      border-top:2px solid #3A6061;
      border-bottom:2px solid #3A6061;
      margin-top:5px;
      margin-bottom:15px;
      height:calc(var(--font-size) + 6px);
      font-weight:normal;
      padding:6px 6px 0;
      .CX2 .today .slotHeader { /* today slot /
      background-color:#afcecf;
      /* background-color:#080a0a;*/
      color:#999;
      .CX2 .today .slotHeader * {
      color:#999;
      .CX2 .today .slotSubTitle {
      color:#3A6061;
      .CX2 .weekSlot {
      position:relative;
      .CX2 .today.slot {
      /*background-color:#afcecf;*/
      background-color:#0a1010;
      border:4px solid #1d2f30;
      .CX2 .slot > .slotContent{
      position:relative;
      width:100%;
      background-image: none;
      .CX2 .module-content { /* fake module body */
      color:#999;
      font-family: 'Roboto', sans-serif;
      .CX2 .weeksmark {
      display:none;
      /***** Event *****/
      .CX2 .event {
      padding:5px;
      margin:12px 0 0 8px;
      background-color:transparent;
      position:relative;
      text-align:left;
      /* how to treat full day events*/
      .CX2 .event.fullday {
      border-radius:unset;
      color:#999;
      if (typeof module !== "undefined") {module.exports = config;}```
      Any help is greatly appreciated. Says its on 77, and have tried everything. This is from JShint (I know its going to be something stupid.
      93	Expected ']' to match '[' from line 92 and instead saw ':'.
      93	Expected '}' to match '{' from line 91 and instead saw 'calendar-check'.
      96	Unrecoverable syntax error. (39% scanned).
        sdetweil @jwest35
        @jwest35 unexpected token means the line before the error does not have a trailing comma.
        general rules
        the thing to the left of : does not need to be quoted
        to the right of the colon does not need quotes it it is a number, or is true or false.
        otherwise it needs quotes. either kind will work, as long as the start and end are the same.
        if the next line starts with a word, then this line needs to end with a comma
          Alvinger @sdetweil
          @jwest35, you’re missing a left curly brace.
            sdetweil @Alvinger
            @Alvinger right, after the calendarExt2 url line
