    Copy & paste question
    4 Posts 2 Posters 691 Views 2 Watching
    • N Offline
      norwestie
      What should I use to paste the instructions into the config.js file? I’m guessing as to the indent location for the various lines and apparently that makes a difference.
        sdetweil @norwestie
        @norwestie indent does not matter.
        use ssh and winscp from windows, and any text editor ( I use notepad++) to edit.
        typical double click to edit
        find the end of the prior module
        and paste in after, add a comma after the prior of it doesn’t have one ( means more following)
        • N Offline
          norwestie
          Thank you. I must have made other errors
            sdetweil @norwestie
            @norwestie do
            npm  run config:check
            from the MagicMirror folder, work from the top down, one error at a time
            unexpected token usually means a missing comma on the line before the one reported
