    • Search
    Plot data from a local CSV file
    Requests
    • J
      jhillairet last edited by
      Dear all,
      I’m storing locally on my raspberry some data fetched from other sources every minutes, and I would like to plot them dynamically on a magic mirror module. These data are like:
      date1 time1 values1
      date2 time2 values2
      date3 time3 values3
      While I’m OK in Python, I know nothing to Javascript. So I can format the .csv file to something else if needed, but I don’t know what module I can use to do the job.
      Is anyone could indicate me how I could do that ? Many thanks in advance
      Best regards,
        sdetweil @jhillairet last edited by
        @jhillairet see the 3rd party module list
        https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
        there is a json->graph module
        • J
          Thank you. However, most (all?) appear not being developed any more (or only support bar graph), unless I’m missing something?.
            @jhillairet yes, many modules no longer have current activity from their creator. they made them for their purposes…
            I use chartjs for my covid 19 charting module, and other apps reading data from csv, but I don’t read generic csv files
            • J
              Is your work available online?
                @jhillairet sure
                https://github.com/sdetweil/MyCovid19
                • J
                  thank you
                    sdetweil @jhillairet last edited by sdetweil
                    @jhillairet I get all the data and format/filter in the node_helper, then send to the modulename.js to display.
                    as I support multiple instance the messages have the module indentifier to keep the data separated
