    black image after update google assistant
    5 Posts 2 Posters 925 Views 2 Watching
    • R
      raf
      I have done an update to my google assistant and now I only have a black screen (if I disable the google assistant in the config.js the mirror will work) what should I do now?
        sdetweil @raf
        @raf look in the console where u started MM (or pm2 logs) to see if there are any errors
        and also look in the developers window
        ctrl-shift-i, select the tab labeled console
        and scroll up to see any errors
        • R
          raf @sdetweil
          is this what you mean
          [2020-11-14 17:35:08.225] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
          Require stack:
          - /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
          - /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js
          - /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
          [2020-11-14 17:35:08.248] [ERROR]  App threw an error during load
          [2020-11-14 17:35:08.250] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
          Require stack:
              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
              at Module.require (internal/modules/cjs/loader.js:685:19)
              at require (internal/modules/cjs/helpers.js:16:16)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
              at Module._compile (internal/modules/cjs/loader.js:786:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
              at Module.load (internal/modules/cjs/loader.js:645:32)
          [2020-11-14 17:35:08.256] [ERROR]  Whoops! There was an uncaught exception...
          [2020-11-14 17:35:08.257] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
          Require stack:
              at Module.load (internal/modules/cjs/loader.js:645:32) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js',
              '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js',
              '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js',
              '/home/pi/MagicMirror/js/app.js',
              '/home/pi/MagicMirror/js/electron.js',
              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
              undefined
          [2020-11-14 17:35:08.272] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-11-14 17:35:08.273] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            sdetweil @raf
            @raf thats the cause of the black screen, I don’t see any info on fixing it expect this note
            Don't forget to do ALL electron-rebuild steps.
            so, lets try
            cd ~/MagicMirror
            npm install electron-rebuild
            cd modules/MMM-GoogleAssistant
            ~/MagicMirror/node_modules/.bin/electron-rebuild
            then try to start MM again
            • R
              raf @sdetweil
              okay Sam thanks again it works back
