Navigation
    • Search
    Acces IP Whitelist
    Troubleshooting
    • G
      greda last edited by
      I have a little problem. I configured config.js like this: ipWhitelist: [“127.0.0.1”, “:: ffff: 127.0.0.1”, “:: 1”, “192.168.0.0/24”, ":: ffff: 192.168. 0.0 / 24 "], // Set [] to allow all IP addresses
      But I can’t access the mirror from a browser. My internal ip is 192.168.0.0/24
      Thank you for your help.
        sdetweil @greda last edited by
        @greda what is address set to? must be “0.0.0.0” to allow access from off the mirror machine.
        localhost means ONLY listen for inside connections…
        ipWhitelist applies AFTER that
        • G
          @sdetweil said in Acces IP Whitelist:
          How do I configure the ipWhitelist line?
          Currently: ipWhitelist: [“127.0.0.1”, “:: ffff: 127.0.0.1”, “:: 1”],
            @greda first start with
            ipWhitelist:[],
            anyone on your (local) network could connect
            • G
              Thanks it’s ok now.
