    new update Assistant2Display
    27 Posts 4 Posters 6.9k Views 4 Watching
    • ? Offline
      A Former User
      so, user (pi) is correct
      but can you explain to me why file mod is changed in installer directory ?
      just because in repository it’s a different chmod …
        raf @Guest
        @Bugsounet
        I have no explanation for it, I am a real layman and it all sounds Chinese to me
        I really don’t know anything about it but I think it’s a great project and that’s why I installed it on my pi
        but I want to take your advice and try to make any changes you suggest
        • ? Offline
          A Former User
          I think you do some commands but you don’t know what is means so the result is : You have broken all install system and all update system
          So to repair:
          make executable all sh file of installer directory
          R ? 2 Replies Last reply Reply Quote 0
            raf @Guest
            @Bugsounet
            I don’t know how to do that, maybe someone via team viewer
            • ? Offline
              A Former User
              chmod +x
                raf @Guest
                @Bugsounet
                and where do I carry out this assignment
                • ? Offline
                  A Former User @Guest
                  I says:
                  So to repair:
                  just read and search …
                  I will don’t tell you the entire command
                  I just tell to you a part of the command (chmod +x)… now just search a little
                  sorry … you do some commands without search the signification, so now search
                  You have internet and you have google, you have the part of command… better way for learning ;)
                  For your information, it’s not an Assistant2Display issue (all setting is correct in the repository) it’s just a mismake user command issue
                    raf @Guest
                    @Bugsounet
                    I’m trying my best
                      raf
                      I’ll just remove the google assistant and assistant2display because I can’t find the error (then just a mirror without assistant)
                      thank you in advance
                      ? 1 Reply Last reply Reply Quote -1
                      • ? Offline
                        A Former User @raf
                        @raf no problem make as you want but don’t ask helping if you make some mismake command by your self
                        I think it not very difficult to search the syntaxe for chmod +x some files
                        If you don’t want to search a little on Google, I can’t do anything for you
                        All module are free… We send you the Way to find and correct User error.
                        I repeat it s not an A2D error or an A2D mismake script
                        It a mismake command by yourself
                        By your react you will never understand anything.
                        Good luck for future ;)
                        @bugsounet
                        • 3 / 3
