    new update Assistant2Display
    27 Posts 4 Posters 9.1k Views 4 Watching
      A Former User @Guest
      I says:
      So to repair:
      make executable all sh file of installer directory
      just read and search …
      I will don’t tell you the entire command
      I just tell to you a part of the command (chmod +x)… now just search a little
      sorry … you do some commands without search the signification, so now search
      You have internet and you have google, you have the part of command… better way for learning ;)
      For your information, it’s not an Assistant2Display issue (all setting is correct in the repository) it’s just a mismake user command issue
      R 1 Reply Last reply
        raf @Guest
        @Bugsounet
        I’m trying my best
          raf
          I’ll just remove the google assistant and assistant2display because I can’t find the error (then just a mirror without assistant)
          thank you in advance
          ? 1 Reply Last reply
          Reply Quote -1
            A Former User @raf
            @raf no problem make as you want but don’t ask helping if you make some mismake command by your self
            I think it not very difficult to search the syntaxe for chmod +x some files
            If you don’t want to search a little on Google, I can’t do anything for you
            All module are free… We send you the Way to find and correct User error.
            I repeat it s not an A2D error or an A2D mismake script
            It a mismake command by yourself
            By your react you will never understand anything.
            Good luck for future ;)
            @bugsounet
              raf @Guest
              @Bugsounet
              because I like the module too much I don’t remove it after months of work that it has already taken me to install it, so look a little further:face_savouring_delicious_food:
                raf
                could I solve it with this script?
                bash -c " $ ( curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh ) "
                S 2 Replies Last reply
                  sdetweil @raf
                  @raf no, that is only to upgrade MagicMirror itself
                    sdetweil @raf
                    @raf please see this
                    https://www.hostinger.com/tutorials/linux-commands
                    and here
                    https://maker.pro/linux/tutorial/basic-linux-commands-for-beginners
                    cause it has a different start , which may prove helpful forever
                      raf
                      I’ve read a lot but don’t know where to start
                      I even don’t know where to look for the error let alone fix it
                        sdetweil @raf
                        @raf come on, commands are executed in a terminal window. the second link shows you how to open one from the desktop.
                        some commands work on files…
                        so you either need to be in the same folder as the files, or use the full path to the files from the current folder.
                        u know the error, u and Bugsounet have discussed it… the program needs to be marked executable… this is a linux permissions thing, you cannot execute just anything… (like on windows)
                        u need to learn the system , and will be better off because of it. we are not here to give u every command in every situation…
                          raf @sdetweil
                          i am thinking of an issue with the electron rebuild, if i disable Assistant2Display in the config.js the mirror will boot normally but if i enable it back in the config.js i only get a black image
                            A Former User
                            when you clone the repo, all needed files have the the executable flag … you have change it so … we give the way … now search
                            All of my module have same scheme… if there is some probleme all of my module will be impected
                            It’s not the case For you information : A2D is downloaded +/- 500X per week
                            So now you have make a mismake … now search, you have the way …
                            we can’t tell you better and we can’t do better ;)
                            we are not magican
                            Or like you says :
                            @raf said in new update Assistant2Display:
                            it’s the best choice for you BUT don’t ask to me or @sdetweil some help in this case
                            and plz don’t notify me in future
                              raf
                              problem finally solved
                                banbutcher
                                @raf how did you solve it, incase anyone else hase the same issue?
                                  A Former User @banbutcher
                                  @banbutcher… It s not an issue
                                    raf
                                    I solved it by disabling the Assistant2Display in the config.js and then after removing the folder in the modules folder,
                                    then done the installation back git clone … and enabled the module back in the config.js and what changed in the config changed to mine
                                      A Former User @raf
                                      Mouahah!
                                      Rassure me… When you have a problem with you computer you don’t change it? Mouahahah
                                      So for resume… You have change installer file to don’t execute it
                                      Result… You disable it… Delete de directory… Git clone it… Reinstall it…
                                      Yeahh ;)
                                      Mouahahah lost time
                                      I think I’m so stupid… When I do an error… I have to try your method… But I will lost all my work! Mouahahahahah
                                      You do a command… You don’t know the signification… Result we give the way… And you don’t find mouahahah
                                      The command in the installer directory For repair your mismake serial command is:
                                      ‘chmod +x *.sh’
                                      And pouuf it repair… You have Wikipedia… You don’t want to read it… A single search on Google and you have the result… To lazy to do this mouahahahah
                                      Sorry, mouahahahah
