    new update Assistant2Display
    27 Posts 4 Posters 8.9k Views 4 Watching
      raf @Guest
      @Bugsounet
      because I like the module too much I don’t remove it after months of work that it has already taken me to install it, so look a little further:face_savouring_delicious_food:
        raf
        could I solve it with this script?
        bash -c " $ ( curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh ) "
          sdetweil @raf
          @raf no, that is only to upgrade MagicMirror itself
            sdetweil @raf
            @raf please see this
            https://www.hostinger.com/tutorials/linux-commands
            and here
            https://maker.pro/linux/tutorial/basic-linux-commands-for-beginners
            cause it has a different start , which may prove helpful forever
              raf
              I’ve read a lot but don’t know where to start
              I even don’t know where to look for the error let alone fix it
                sdetweil @raf
                @raf come on, commands are executed in a terminal window. the second link shows you how to open one from the desktop.
                some commands work on files…
                so you either need to be in the same folder as the files, or use the full path to the files from the current folder.
                u know the error, u and Bugsounet have discussed it… the program needs to be marked executable… this is a linux permissions thing, you cannot execute just anything… (like on windows)
                u need to learn the system , and will be better off because of it. we are not here to give u every command in every situation…
                  raf @sdetweil
                  i am thinking of an issue with the electron rebuild, if i disable Assistant2Display in the config.js the mirror will boot normally but if i enable it back in the config.js i only get a black image
                    A Former User
                    when you clone the repo, all needed files have the the executable flag … you have change it so … we give the way … now search
                    All of my module have same scheme… if there is some probleme all of my module will be impected
                    It’s not the case For you information : A2D is downloaded +/- 500X per week
                    So now you have make a mismake … now search, you have the way …
                    we can’t tell you better and we can’t do better ;)
                    we are not magican
                    Or like you says :
                    @raf said in new update Assistant2Display:
                    I’ll just remove the google assistant and assistant2display because I can’t find the error (then just a mirror without assistant)
                    it’s the best choice for you BUT don’t ask to me or @sdetweil some help in this case
                    and plz don’t notify me in future
                      raf
                      problem finally solved
                        banbutcher
                        @raf how did you solve it, incase anyone else hase the same issue?
                          A Former User @banbutcher
                          @banbutcher… It s not an issue
                            raf
                            I solved it by disabling the Assistant2Display in the config.js and then after removing the folder in the modules folder,
                            then done the installation back git clone … and enabled the module back in the config.js and what changed in the config changed to mine
                              A Former User @raf
                              Mouahah!
                              Rassure me… When you have a problem with you computer you don’t change it? Mouahahah
                              So for resume… You have change installer file to don’t execute it
                              Result… You disable it… Delete de directory… Git clone it… Reinstall it…
                              Yeahh ;)
                              Mouahahah lost time
                              I think I’m so stupid… When I do an error… I have to try your method… But I will lost all my work! Mouahahahahah
                              You do a command… You don’t know the signification… Result we give the way… And you don’t find mouahahah
                              The command in the installer directory For repair your mismake serial command is:
                              ‘chmod +x *.sh’
                              And pouuf it repair… You have Wikipedia… You don’t want to read it… A single search on Google and you have the result… To lazy to do this mouahahahah
                              Sorry, mouahahahah
