new update Assistant2Display
@Bugsounet
I have no explanation for it, I am a real layman and it all sounds Chinese to me
I really don’t know anything about it but I think it’s a great project and that’s why I installed it on my pi
but I want to take your advice and try to make any changes you suggest -
I think you do some commands but you don’t know what is means so the result is : You have broken all install system and all update system
So to repair:
make executable all sh file of installer directory -
I don’t know how to do that, maybe someone via team viewer
chmod +x
@Bugsounet
and where do I carry out this assignment -
I says:
So to repair:
make executable all sh file of installer directoryjust read and search …
I will don’t tell you the entire command
I just tell to you a part of the command (chmod +x)… now just search a little
sorry … you do some commands without search the signification, so now searchYou have internet and you have google, you have the part of command… better way for learning ;)
For your information, it’s not an Assistant2Display issue (all setting is correct in the repository) it’s just a mismake user command issue
@Bugsounet
I’m trying my best -
I’ll just remove the google assistant and assistant2display because I can’t find the error (then just a mirror without assistant)
thank you in advance -
@raf no problem make as you want but don’t ask helping if you make some mismake command by your self
I think it not very difficult to search the syntaxe for chmod +x some files
If you don’t want to search a little on Google, I can’t do anything for youAll module are free… We send you the Way to find and correct User error.
I repeat it s not an A2D error or an A2D mismake script
It a mismake command by yourself
By your react you will never understand anything.
Good luck for future ;) -
@Bugsounet
because I like the module too much I don’t remove it after months of work that it has already taken me to install it, so look a little further:face_savouring_delicious_food: -
could I solve it with this script?
bash -c " $ ( curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh ) "
@raf no, that is only to upgrade MagicMirror itself
@raf please see this
https://www.hostinger.com/tutorials/linux-commands
and here
https://maker.pro/linux/tutorial/basic-linux-commands-for-beginnerscause it has a different start , which may prove helpful forever
I’ve read a lot but don’t know where to start
I even don’t know where to look for the error let alone fix it -
@raf come on, commands are executed in a terminal window. the second link shows you how to open one from the desktop.
some commands work on files…
so you either need to be in the same folder as the files, or use the full path to the files from the current folder.
u know the error, u and Bugsounet have discussed it… the program needs to be marked executable… this is a linux permissions thing, you cannot execute just anything… (like on windows)
u need to learn the system , and will be better off because of it. we are not here to give u every command in every situation…
i am thinking of an issue with the electron rebuild, if i disable Assistant2Display in the config.js the mirror will boot normally but if i enable it back in the config.js i only get a black image -
when you clone the repo, all needed files have the the executable flag … you have change it so … we give the way … now search
All of my module have same scheme… if there is some probleme all of my module will be impected
It’s not the case For you information : A2D is downloaded +/- 500X per week
So now you have make a mismake … now search, you have the way …
we can’t tell you better and we can’t do better ;)we are not magican
Or like you says :
@raf said in new update Assistant2Display:
it’s the best choice for you BUT don’t ask to me or @sdetweil some help in this case
and plz don’t notify me in future -
problem finally solved
@raf how did you solve it, incase anyone else hase the same issue?
@banbutcher… It s not an issue
