    Problems loading config resources
    3 Posts 2 Posters 829 Views 2 Watching
    • E Offline
      Envynot
      Not very good with software so bear with me here. The issue I’m having comes after I’ve installed MagicMirror when I go to run the program; I’m met with a black screen. When I npm start dev I can see in the console that the config file has several errors:
      “Failed to load resource: the server responded with a status of 404 (not found)”,
      “Refused to apply style from ‘’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.”,
      “error on loading stylesheet: vendor/css/font-awesome.css”.
      etc.
      There are are about 15 of these errors and I have no clue how to troubleshoot this. I have already tried removing the MagicMirror folder completely and reinstalling from scratch. I’m guessing the issue has to do with a problem in the config file. So I tried renaming config.js.sample to config.js, didn’t work. Also tried copying config.js.sample and renaming the copy, didn’t work. When I start the program with just the config.js.sample instead of being met with a black screen I am met with several lines of text that say “undefined”. Let me know if there is another way to give more information so I get to the bottom of this problem! I need this project done before Christmas because it’s a gift!
        sdetweil @Envynot
        @Envynot sounds like you are running on windows…
        two extra steps
        cd MagicMirror
        cd vendor
        npm install
        cd ..
        cd fonts
        npm install
        cd ..
        now u can start mm again
        • E Offline
          Envynot
          @sdetweil said in Problems loading config resources:
          two extra steps
          cd MagicMirror
          cd vendor
          npm install
          cd ..
          cd fonts
          npm install
          cd ..
          Ah my guy. You are a saint. Thank you so much! Happy holidays!
