    compliments reduce font size and move down a little bit
    4 Posts 3 Posters 1.4k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hello everyone and have a nice Christmas,
      where in which css file can I reduce the font of “compliments”? and how with which variables ?? and move a little bit down in the mirror?
      Thank you very much for a short feedback.
        sdetweil @kusselin
        @kusselin u always put css changes in custom.css
        once u know the class to change
        according to the doc, compliments uses
        classes	Override the CSS classes of the div showing the compliments
        Default value: thin xlarge bright
        which u can change in config, or you can override in custom.css
        .modulename .class { … }
        u might be able to use large instead of xlarge (for the size part)
        • kusselinK Offline
          kusselin
          hello sam…, but where can i find the css class…in custom.css i don´t find anythin also in main.css… :-(
          EDIT:
          O.K. i found this in main.css and put this with smaller numbers…then it´s ok.
          Thank you sam
          • K Offline
            keineAhnung123
            Hello @sdetweil
            I have a similar question: I want the compliments module to have the same appearance as the title of the newsfeed module.
            found in newsfeed-code:
            			if (!this.config.showFullArticle) {
            				const title = document.createElement("div");
            				title.className = "newsfeed-title bright medium light" + (!this.config.wrapTitle ? " no-wrap" : "");
            				title.innerHTML = this.newsItems[this.activeItem].title;
            				wrapper.appendChild(title);
            so i want the compliments style to be “bright medium light”
            the compliments code shows
            	getDom: function () {
            		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright pre-line";
            Im not sure how to modify the custom.css.
            Something like:
            .compliments .class {
            bright medium light;
            Can you help me? :)
