    MMM-Keybindings evdev module install error
    5 Posts 2 Posters 672 Views 2 Watching
      DeMaddin
      Hello.
      I tried to install MMM-Keybindings on a fresh MM installation (pi4, raspi os buster) but unfortunately i cannot manage.
      I want to use the FireTV bluetooth remote!
      After npm install in Keybindings directory i get this error```
      code_text
      MMM-KeyBindings@1.3.1 postinstall /home/pi/MagicMirror/modules/MMM-KeyBindings
      ./postinstall.sh
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/evdev/build“ wird betreten
      CXX(target) Release/obj.target/ioctls/src/ioctls.o
      In file included from /home/pi/.electron-gyp/6.1.12/include/node/v8-internal.h:14,
      from /home/pi/.electron-gyp/6.1.12/include/node/v8.h:25,
      from /home/pi/.electron-gyp/6.1.12/include/node/node.h:63,
      from …/…/nan/nan.h:56,
      from …/src/ioctls.cc:1:
      /home/pi/.electron-gyp/6.1.12/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
      declarator attribute((deprecated(message)))
      /home/pi/.electron-gyp/6.1.12/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
      V8_DEPRECATE_SOON("Use WithData version.",
      /home/pi/.electron-gyp/6.1.12/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
      …/src/ioctls.cc:10:11: error: ‘v8::Handle’ has not been declared
      using v8::Handle;
      In file included from …/…/nan/nan.h:56,
      /home/pi/.electron-gyp/6.1.12/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (
      )(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (
      )(v8::Locct>)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
      (node::addon_register_func) (regfunc),
      /home/pi/.electron-gyp/6.1.12/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
      NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
      …/src/ioctls.cc:46:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(ioctls, Init)
      In file included from /home/pi/.electron-gyp/6.1.12/include/node/node.h:63,
      /home/pi/.electron-gyp/6.1.12/include/node/v8.h: In instantiation of ‘void v8::PersistentBase::SetWeak(P*, typename v8::WeakCallbackInfo
      ::Callback, v8::WeakCallbackType) [with P = tWrap; T = v8::Object; typename v8::WeakCallbackInfo
      ::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
      /home/pi/.electron-gyp/6.1.12/include/node/node_object_wrap.h:84:78: required from here
      /home/pi/.electron-gyp/6.1.12/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
      )(const v8ackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
      reinterpret_cast(callback), type);
      ::Callback, v8::WeakCallbackType) [with P = Wrap; T = v8::Object; typename v8::WeakCallbackInfo
      ::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
      …/…/nan/nan_object_wrap.h:65:61: required from here
      /home/pi/.electron-gyp/6.1.12/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
      )(const v8:ckInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
      make: *** [ioctls.target.mk:105: Release/obj.target/ioctls/src/ioctls.o] Fehler 1
      make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/evdev/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 5.4.79-v7l+
      gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/.bin/node-gyp” “rebuild” “–target=6.1.12” “–arch=arm” “–dist-url=https://www.electronjs.org--build-from-source”
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/evdev
      gyp ERR! node -v v10.21.0
      gyp ERR! node-gyp -v v6.1.0
      gyp ERR! not ok
      Failed with exit code: 1
      Error: make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/evdev/build“ wird betreten
      using v8::Handle;
      gyp ERR! not ok
      at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/spawn-rx/lib/src/index.js:267:84)
      at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:205:16)
      at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:156:26)
      at Subscriber._error (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:92:26)
      at Subscriber.error (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:72:18)
      at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:92:26)
      at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:72:18)
      at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/spawn-rx/lib/src/index.js:242:65)
      at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_modules/rxjs/internal/Subscriber.js:143:22)
      npm notice created a lockfile as package-lock.json. You should commit this file.
      added 182 packages from 131 contributors and audited 182 packages in 57.601s
      4 packages are looking for funding
      run npm fund for details
      found 0 vulnerabilities
      i am trying this for weeks now, but nothing i found on the forum seems to help.
      Does anyone know how to solve this problem?
      Thanks in advance
      Martin
        sdetweil @DeMaddin
        @DeMaddin looks like this error (fallback to build) was reported in april 2019, but has not been resolved… the module has not been updated in 2 years.
          DeMaddin
          Oh.
          Is there an other module for bluetooth remote control?
          If i enter MagicMirror/modules/MMM-Keybindings/node_modules/evdev and do a “npm install” i get the following error on start of MagicMirror:
          |MagicMirror  | Whoops! There was an uncaught exception...
          0|MagicMirror  | [2020-12-27 18:07:35.102] [ERROR]
          0|MagicMirror  | Error: The module '/home/pi/MagicMirror/modules/MMM-KeyBindings                                             /node_modules/evdev/build/Release/ioctls.node'
          0|MagicMirror  | was compiled against a different Node.js version using
          0|MagicMirror  | NODE_MODULE_VERSION 64. This version of Node.js requires
          0|MagicMirror  | NODE_MODULE_VERSION 73. Please try re-compiling or re-installin                                             g
          0|MagicMirror  | the module (for instance, using `npm rebuild` or `npm install`)                                             .
          0|MagicMirror  |     at process.func (electron/js2c/asar.js:138:31)
          0|MagicMirror  |     at process.func [as dlopen] (electron/js2c/asar.js:138:31)
          0|MagicMirror  |     at Object.Module._extensions..node (internal/modules/cjs/lo                                             ader.js:828:18)
          0|MagicMirror  |     at Object.func (electron/js2c/asar.js:138:31)
          0|MagicMirror  |     at Object.func [as .node] (electron/js2c/asar.js:138:31)
          0|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:645:32)
          0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:56                                             0:12)
          0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:685:19)
          0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:16:16)
          0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Key                                             Bindings/node_modules/evdev/lib/Device/index.js:1:14)
          0|MagicMirror  | [2020-12-27 18:07:35.106] [ERROR]  MagicMirror will not quit, b                                             ut it might be a good idea to check why this happened. Maybe no internet connect                                             ion?
          0|MagicMirror  | [2020-12-27 18:07:35.108] [ERROR]  If you think this really is                                              an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirro                                             r/issues
          Are you sure there is no way getting it to work?
            sdetweil @DeMaddin
            @DeMaddin u need to run electron-rebuild, but that is the step that failed previously
            i don’t know how to fix it, or any other solution
              DeMaddin
              ok. too bad.
              Thank you very much.
              Martin
