    MM only server version working due to issues with config file
    33 Posts 3 Posters 11.1k Views 3 Watching
    • L Offline
      legan @sdetweil
        sdetweil @legan
        @legan weird, can u show results of
        ls ~/MagicMirror/config -laF
        • L Offline
          legan @sdetweil
          Of course, here you are :)
            sdetweil @legan
            @legan ok, on that error screen, ctrl-shift-i to open the developers window, then select the console tab and scroll up there should be an error at the top…
            the code does
            try {
            			fs.accessSync(configFilename, fs.F_OK);  // make sure we have permission to access file
            			var c = require(configFilename);    // load and parse config
            			checkDeprecatedOptions(c);
            			var config = Object.assign(defaults, c);   // overlay defaults with config
            			callback(config);   // send back the loaded config
            		} catch (e) {  // some error above
            			if (e.code === "ENOENT") {    // if file not found
            				Log.error(Utils.colors.error("WARNING! Could not find config file. Please create one. Starting with default configuration."));
            			} else if (e instanceof ReferenceError || e instanceof SyntaxError) {  // got a syntax error
            				Log.error(Utils.colors.error("WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: " + e.stack));
            			} else {  // everything else
            				Log.error(Utils.colors.error("WARNING! Could not load config file. Starting with default configuration. Error found: " + e));
            			callback(defaults);    // < this is sending back the module config that displays the error you see
            • L Offline
              legan
              @sdetweil thanks you very much! Ok, I opened the developer window as you suggested and attached the screenshots of the errors. Where exactly should I paste your code snippet?2.JPG 3.JPG 4.JPG
                sdetweil @legan
                @legan I was just showing what the code DOES…
                custom.css error is because its not there by default…
                • L Offline
                  legan @sdetweil
                  @sdetweil ok sorry, I am not very familiar with java script yet…
                    sdetweil
                    very weird… lets do this
                    cd ~/MagicMirror
                    npm run config:check
                    • L Offline
                      legan @sdetweil
                      @sdetweil no syntax errors…
                        sdetweil @legan
                        @legan said in MM only server version working due to issues with config file:
                        thx… as expected…
                        can u check the filename , rename config.js and make sure no leading/trailing space
                        also can u try with a browser on pi to open
                        file:///home/pi/MagicMirror/config/config.js
                        • 2 / 4
