    MM only server version working due to issues with config file
    33 Posts 3 Posters 10.2k Views 3 Watching
    • L Offline
      legan
      Yes, I checked the filename several times, its fine. The config file is also accessible via file:///home/pi/MagicMirror/config/config.js
        sdetweil @legan
        @legan can I see the address: and ipWhitelist: settings from config.js
          sdetweil
          make them
          address:"0.0.0.0",
          ipWhitelist:[],
          • L Offline
            legan @sdetweil
            @sdetweil I extended the whitelist and enabled all IP addresses. But still not working
              sdetweil @legan
              @legan if u set it to [] that is all
              • L Offline
                legan @sdetweil
                @sdetweil said in MM only server version working due to issues with config file:
                all
                exactly, that’s what I did
                  sdetweil @legan
                  @legan and address is localhost or 0.0.0.0?
                  • L Offline
                    legan
                    @sdetweil now it’s working! Thank you very much you saved my tech mood though! :D
                    Have a good one! :)
                      sdetweil @legan
                      @legan what did you do ?
                      • L Offline
                        legan @sdetweil
                        @sdetweil I followed your instructions, and after changing localhost to 0.0.0.0.
                        I was able to start the mirror
                        • 3 / 4
