    Reload in newsfeed module stops after some minutes
    2 Posts 1 Posters 427 Views 1 Watching
    • schwoediauerS Offline
      schwoediauer
      Hi All,
      I have an new Installation of my MagicMirror with an newsfeed on it, but the reload of the rss feed works not correct. After the start the reload works sometimes one or two times and after that it stops without any error in the log files. Has someone an idea??
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "....laufende Einsätze OÖ",
                                                      url: "http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml",
                                                      encoding: "UTF-8" //ISO-8859-1
                                      reloadInterval: 600000,
                                      showSourceTitle: true,
                                      showPublishDate: true,
                                      showDescription: true,
                                      wrapDescription: true,
                                      broadcastNewsFeeds: false,
                                      broadcastNewsUpdates: false,
                                      startTags: ['channel', 'image'],
                                      ignoreOldItems: true,
                                      ignoreOlderThan: 10800000,
                                      logFeedWarnings: true
      extract of pm2 Logfiles:
      pi@pi_mirror:~/MagicMirror $ cat /home/pi/.pm2/logs/mm-out-0.log | grep news
      [14.01.2021 06:49.11.230] [LOG] Module helper loaded: newsfeed
      [14.01.2021 06:49.11.463] [LOG] Connecting socket for: newsfeed
      [14.01.2021 06:49.11.465] [LOG] Starting node helper for: newsfeed
      [14.01.2021 06:49.15.713] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      [14.01.2021 06:51.04.270] [LOG] Module helper loaded: newsfeed
      [14.01.2021 06:51.04.607] [LOG] Connecting socket for: newsfeed
      [14.01.2021 06:51.04.609] [LOG] Starting node helper for: newsfeed
      [14.01.2021 06:51.10.758] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      [14.01.2021 09:35.52.033] [LOG] Stopping module helper: newsfeed
      [14.01.2021 09:36.06.583] [LOG] Module helper loaded: newsfeed
      [14.01.2021 09:36.06.832] [LOG] Connecting socket for: newsfeed
      [14.01.2021 09:36.06.836] [LOG] Starting node helper for: newsfeed
      [14.01.2021 09:36.11.135] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      [14.01.2021 09:40.20.647] [LOG] Module helper loaded: newsfeed
      [14.01.2021 09:40.20.901] [LOG] Connecting socket for: newsfeed
      [14.01.2021 09:40.20.903] [LOG] Starting node helper for: newsfeed
      [14.01.2021 09:40.25.404] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      [14.01.2021 11:56.30.076] [LOG] Stopping module helper: newsfeed
      [14.01.2021 11:56.44.627] [LOG] Module helper loaded: newsfeed
      [14.01.2021 11:56.44.864] [LOG] Connecting socket for: newsfeed
      [14.01.2021 11:56.44.868] [LOG] Starting node helper for: newsfeed
      [14.01.2021 11:56.49.029] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      [14.01.2021 12:03.29.610] [LOG] Module helper loaded: newsfeed
      [14.01.2021 12:03.29.851] [LOG] Connecting socket for: newsfeed
      [14.01.2021 12:03.29.852] [LOG] Starting node helper for: newsfeed
      [14.01.2021 12:03.34.367] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      [14.01.2021 13:22.49.244] [LOG] Stopping module helper: newsfeed
      [14.01.2021 13:23.08.673] [LOG] Module helper loaded: newsfeed
      [14.01.2021 13:23.08.904] [LOG] Connecting socket for: newsfeed
      [14.01.2021 13:23.08.906] [LOG] Starting node helper for: newsfeed
      [14.01.2021 13:23.13.180] [LOG] Create new news fetcher for url: http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml - Interval: 300000
      pi@pi_mirror:~/MagicMirror $ cat /home/pi/.pm2/logs/mm-out-0.log | grep News
      [14.01.2021 09:40.26.002] [INFO] Newsfeed-Fetcher: Broadcasting 2 items.
      —restart
      [14.01.2021 12:03.35.214] [INFO] Newsfeed-Fetcher: Broadcasting 2 items.
      [14.01.2021 12:08.35.406] [INFO] Newsfeed-Fetcher: Broadcasting 1 items.
      [14.01.2021 12:13.35.544] [INFO] Newsfeed-Fetcher: Broadcasting 1 items.
      [14.01.2021 13:23.13.834] [INFO] Newsfeed-Fetcher: Broadcasting 1 items.
      —restart
        schwoediauer
        I’ve tested my config with several other RSS Feeds and I can see the problem only with the feed listet in the description, all other feed works fine .
        I have no idea what happens. Do I have any further log informations for debugging the situation??
