    I am a Node.js noob and I created a module for interfacing with a keypad connected to my arduino. The Arduino communicates to my RPi via serial USB. My application keeps crashing...
    4 Posts 2 Posters 520 Views 2 Watching
    • G Offline
      glorianneef
      I have checked for configuration errors and this is all fine. Everything seems to go smoothly until I add my node_helper.js. I will upload my config file, main module file, and my helper. Any help would be appreciated. Can’t seem to find the reason for breaking my Magic mirror. =
      MMM-Timer.js
      Module.register("MMM-Timer", {
      // Default module config.
         defaults: {
         	text: "Hello World!"
         // Override dom generator.
         getDom: function() {
         	wrapper.innerHTML = this.config.text;
         	return wrapper;
         start: function() {
         	this.mySpecialProperty = "So much wow!";
         	Log.log(this.name + ' is started!');
         	var self = this;
         	setInterval(function() {
         	self.updateDom(); // no speed defined, so it updates instantly.
         		}, 1000); //perform every 1000 milliseconds.
         notificationReceived: function(notification, payload, sender) {
         	if (sender) {
         		Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
         	} else {
         		Log.log(this.name + " received a system notification: " + notification);
         	Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
      node_helper.js
      var NodeHelper = require("node_helper");
      const { spawn } = require('child_process');
      const child = spawn('~/serial_communication.py');
      	start: function() {
      	stop: function() {
      		console.log("Shutting down MyModule");
      		console.log('kill');
          		child.kill();
      		this.connection.close();
      	// Override socketNotificationReceived method.
      	// Test another function
      	aFunction: function() {
      		child.stdout.on('data', (data) => {
        			console.log(`child stdout:\n${data}`);
      		child.stderr.on('data', (data) => {
        			console.error(`stderr: ${data}`);
      		child.on('close', (code) => {
        			console.log(`child process exited with code ${code}`);
      		//want to return the python subprocess
      		this.sendSocketNotification('MY_TIMER_DATA', data);
        sdetweil @glorianneef
        @glorianneef move sendsocketnotification in the data.on handler
        child.stdout.on('data… ()=>{
        sendsocketnotification(notice, data)
        on phone, best i can do
        • G Offline
          glorianneef
          Thank you for the reply!
          However, I sadly am still shown a black screen of doom… not too sure.
            @glorianneef dont copy exactly from my posts
            i wouldnt start the spawn unstil start time
