    0First Time setup. Will not launch with 2 added modules
    4 Posts 2 Posters 660 Views 2 Watching
      avsfanwilly15
      Good day everyone.
      My first time using Magic Mirror. Currently trying to add the MMM-Earth and the MMM-TimesSquare-Live modules. Set up my config in what I thought was the correct way but getting an error when I try and run MM. I will drop my config file as is as well as what the terminal is angrily spitting out at me. Any help would be great! Thanks
      var config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "My Calendar",
      						symbol: "calendar-check",
      						url: "00000"					}
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "5155499", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "00000"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "000000"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "/R/World News",
      						url: "https://www.reddit.com/r/worldnews/.rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
          			module: "MMM-EARTH",
          			position: "bottom_center",
              			mode: "Natural",
              			rotateInterval: 15000,
              			MaxWidth: "50%",
              			MaxHeight: "50%",
      			module: 'MMM-TimesSquare-Live',
      			position: 'top_center',
          				height:"270px",
          				width:"480px",
          				useHeader: ture,
          				header: "",
          				animationSpeed: 1000,
        avsfanwilly15
        And this is what the terminal is saying when I exit MM and look at the startup:
        pi@raspberrypi:~/MagicMirror $ npm run start
        > magicmirror@2.14.0 start /home/pi/MagicMirror
        [26.01.2021 01:28.05.154] [LOG]   Starting MagicMirror: v2.14.0
        [26.01.2021 01:28.05.167] [LOG]   Loading config ...
        [26.01.2021 01:28.05.181] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:103
        SyntaxError: Unexpected token '{'
            at Module._compile (internal/modules/cjs/loader.js:896:18)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
            at Module.load (internal/modules/cjs/loader.js:816:32)
            at Module._load (internal/modules/cjs/loader.js:728:14)
            at Function.Module._load (electron/js2c/asar.js:748:26)
            at Module.require (internal/modules/cjs/loader.js:853:19)
            at require (internal/modules/cjs/helpers.js:74:18)
            at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
            at App.start (/home/pi/MagicMirror/js/app.js:217:3)
            at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:129:7)
        [26.01.2021 01:28.05.188] [LOG]   Loading module helpers ...
        [26.01.2021 01:28.05.458] [LOG]   Initializing new module helper ...
        [26.01.2021 01:28.05.461] [LOG]   Module helper loaded: updatenotification
        [26.01.2021 01:28.05.465] [LOG]   No helper found for module: helloworld.
        [26.01.2021 01:28.05.467] [LOG]   All module helpers loaded.
        [26.01.2021 01:28.05.668] [LOG]   Starting server on port 8080 ...
        [26.01.2021 01:28.05.694] [LOG]   Server started ...
        [26.01.2021 01:28.05.697] [LOG]   Connecting socket for: updatenotification
        [26.01.2021 01:28.05.698] [LOG]   Sockets connected & modules started ...
        [26.01.2021 01:28.06.123] [LOG]   Launching application.
        • L Offline
          lolo @avsfanwilly15
          @avsfanwilly15 in module: “newsfeed”, missing bracket } .
          You should hide appid: and private calendar urls: from config.js when uploading to forum
            avsfanwilly15 @lolo
            @lolo oops didn’t even think of hiding those. I’ll edit them out real quick and also let you know how it works after adding that bracket! Thanks!
