    MMM-Toon: ReferenceError: NodeHelper is not defined
    4 Posts 2 Posters 1.0k Views 2 Watching
    • N Offline
      Nymeia
      Hi Guys, I just tried setting up MMM-Toon to show my thermostat on my MM.
      Everything has been setup as suggested, including the API key etc from Toon, but when i save my config my screen stays black.
      When i Putty to my Pi and run PM2 Logs, i get the following error logs:
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | [29.01.2021 10:26.01.731] [ERROR] Whoops! There was an uncaught exception…
      0|MagicMir | [29.01.2021 10:26.01.738] [ERROR] ReferenceError: NodeHelper is not defined
      0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-Toon/node_helper.js:11:18)
      0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:968:30)
      0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10)
      0|MagicMir | at Module.load (internal/modules/cjs/loader.js:816:32)
      0|MagicMir | at Module._load (internal/modules/cjs/loader.js:728:14)
      0|MagicMir | at Function.Module._load (electron/js2c/asar.js:748:26)
      0|MagicMir | at Module.require (internal/modules/cjs/loader.js:853:19)
      0|MagicMir | at require (internal/modules/cjs/helpers.js:74:18)
      0|MagicMir | at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
      0|MagicMir | at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
      0|MagicMir | [29.01.2021 10:26.01.741] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [29.01.2021 10:26.01.743] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [29.01.2021 10:26.02.399] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
      Does anyone have a clue? Or can point me in the right direction?
      • L Offline
        lolo @Nymeia
        @Nymeia Try to add this on beginning of node_helper
        const NodeHelper = require('node_helper');
        • N Offline
          Nymeia
          @Nymeia said in MMM-Toon: ReferenceError: NodeHelper is not defined:
          :11:18)
          Thank you, this solved it!
          • L Offline
            lolo @Nymeia
            @Nymeia You’re Welcome.
