    MMM-EarthAndMoon brings errors to mmm-moon-phases
    6 Posts 2 Posters 1.4k Views 2 Watching
    • KamiSchamiK Offline
      KamiSchami
      Hello, I would like to use this module. Currently I have installed MMM-MoonPhase.
      The earth should be visible during the day and the moon in the evening. Should go in this module? When I install the module and restart, the screen stays black. Anyone an idea? Of course, I installed the required modules.
      Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
        sdetweil @KamiSchami
        @kamischami what do the startup errors show?
        KamiSchamiK 1 Reply Last reply Reply Quote 0
          KamiSchami @sdetweil
          @sdetweil The screen just stays black. Which log file should I check?
            @kamischami where u do npm start?
            or pm2 logs if u use pm2
            pm2 logs --lines=100
              Ok.
              https://pastebin.com/eSFYBeh2
                KamiSchami @KamiSchami
                Maybe the same, but i run nmp install
                https://forum.magicmirror.builders/topic/10733/blackscreen-after-update-to-v-2-8-0/11
