    Test suite for MagicMirror²
    Scheduled Pinned Locked Moved Upcoming Features
    42 Posts 5 Posters 46.1k Views 6 Watching
      roramirez Core Contributors
      A little update and I requests ideas and help
      Today I’m playing with a test for newsfeed module. Its not functional. I’m using the same MagicMirror as backend for response a feed (in the future can be good idea a fake server for testing purposes).
      The patch can you find on
      https://github.com/roramirez/MagicMirror/commit/db87f9e15b79827e947316c3ffba5b4ca49854b7
      The main case is the waiting the tests for module title and titles of news. There a delay around a 1 second after the “loading…” when is show in screen. Somebody have an idea to gets this test?
      Easy module development with MagicMirror Module Template
        roramirez Core Contributors @roramirez
        I fixed before mentioned https://github.com/roramirez/MagicMirror/commit/2a94ee55ccb8fa06f4d07c2a67307b5ed0a659a3
          The last build of today.
            I mention this here if someone can help
            If use moment-timezone for a test this fail
            • Fail in Travis: https://travis-ci.org/roramirez/MagicMirror/builds/220155902
            • Commit example: https://github.com/roramirez/MagicMirror/commit/05d7c9556e773bf2b941035953200ff327efb476
              Hi Guys, are you still alive?
              Sometimes the build failed, an example here
              https://travis-ci.org/MichMich/MagicMirror/jobs/227577643
              Someone have some idea how to fix this?
              cc @qistoph @strawberry-3-141 @morozgrafix
              Q 1 Reply Last reply Reply Quote 0
              • Q Offline
                qistoph @roramirez
                @roramirez sorry, haven’t had much time to spend on MagicMirror lately.
                My guess is that some of the tests take too long. Especially the ones actually starting MM and not just load a module.
                I imagine Travis runs the tests in some sort of container with multiple containers running on the same system. If there is some heavy load at the same time as the MM test is run this might slow down our test with a certain factor. Seeing the difference in the usual runtime between tests (couple of ms vs multiple seconds) makes me think some of our tests are on the heavier end. Having a multiple second test delayed by a factor, say, 2 makes it easily run 5 seconds. Hitting the 5 sec maximum (see log).
                Two possibilities I see to fix this:
                1. Reduce the runtime of long running tests
                2. Increase the allowed runtime before timeout
                Hopefully this helps.
                Best regards and thanks for keeping this thread alive!
                  roramirez Core Contributors @qistoph
                  @qistoph Well I’ve testing de CircleCI vs Travis.
                  For same Build
                  Failed: https://travis-ci.org/roramirez/MagicMirror/builds/234342109
                  Sucess: https://circleci.com/gh/roramirez/MagicMirror/6
                  • Q Offline
                    qistoph @roramirez
                    @roramirez
                    Except for one of the errors I think all can still be explained by my last post.
                      @qistoph said in Test suite for MagicMirror²:
                      Yes, you’re rigth. Can you help in this area?
                        Yay! After a long fight the test are passing in Travis CI
                        https://github.com/MichMich/MagicMirror/pull/953
                        • 4 / 5
