    Test suite for MagicMirror²
    Scheduled Pinned Locked Moved Upcoming Features
    42 Posts 5 Posters 53.9k Views 6 Watching
      roramirez Core Contributors @qistoph
      @qistoph Sorry, Spanish acronymous. I mean Operating System.
      On the another hand. The same commit is passed in Travis on my personal forked but in the main Mich’s repository failed.
      https://travis-ci.org/roramirez/MagicMirror/builds/200750569 (Pass)
      https://travis-ci.org/MichMich/MagicMirror/builds/200750793 (Fail)
      It’s so weird.
      Q 1 Reply Last reply Reply Quote 0
      • Q Offline
        qistoph @roramirez
        @roramirez my tests ran on Ubuntu.
        The failed build you’re linking has timeouts. That’s the issue I added to the Trello board. We could increase the timeout a bit and see if it happens again in the next days.
        Ask Mich to re-run the failed build, he should be able to click that option in Travis, being the owner of the project. See if that fails again. That resolved it for me before.
          @qistoph it’s pushed https://github.com/MichMich/MagicMirror/pull/716
            Hey guys,
            I pushed up a small refactoring for tests.
            https://github.com/MichMich/MagicMirror/pull/728
            This is a improvement for create new tests without unnecessary repeat inside of code.
            Something I wasnt think now is how can be integrate the case test created by @qistoph because this is set a app.path inside of test (It’s something I have not tried…yet)
            https://github.com/MichMich/MagicMirror/blob/e62df3b3b18cc98b65656194fa5baa53b9110fbc/tests/e2e/dev_console.js#L37
              A little update and I requests ideas and help
              Today I’m playing with a test for newsfeed module. Its not functional. I’m using the same MagicMirror as backend for response a feed (in the future can be good idea a fake server for testing purposes).
              The patch can you find on
              https://github.com/roramirez/MagicMirror/commit/db87f9e15b79827e947316c3ffba5b4ca49854b7
              The main case is the waiting the tests for module title and titles of news. There a delay around a 1 second after the “loading…” when is show in screen. Somebody have an idea to gets this test?
                roramirez Core Contributors @roramirez
                I fixed before mentioned https://github.com/roramirez/MagicMirror/commit/2a94ee55ccb8fa06f4d07c2a67307b5ed0a659a3
                  The last build of today.
                    I mention this here if someone can help
                    If use moment-timezone for a test this fail
                    • Fail in Travis: https://travis-ci.org/roramirez/MagicMirror/builds/220155902
                    • Commit example: https://github.com/roramirez/MagicMirror/commit/05d7c9556e773bf2b941035953200ff327efb476
                      Hi Guys, are you still alive?
                      Sometimes the build failed, an example here
                      https://travis-ci.org/MichMich/MagicMirror/jobs/227577643
                      Someone have some idea how to fix this?
                      cc @qistoph @strawberry-3-141 @morozgrafix
                      • Q Offline
                        qistoph @roramirez
                        @roramirez sorry, haven’t had much time to spend on MagicMirror lately.
                        My guess is that some of the tests take too long. Especially the ones actually starting MM and not just load a module.
                        I imagine Travis runs the tests in some sort of container with multiple containers running on the same system. If there is some heavy load at the same time as the MM test is run this might slow down our test with a certain factor. Seeing the difference in the usual runtime between tests (couple of ms vs multiple seconds) makes me think some of our tests are on the heavier end. Having a multiple second test delayed by a factor, say, 2 makes it easily run 5 seconds. Hitting the 5 sec maximum (see log).
                        Two possibilities I see to fix this:
                        1. Reduce the runtime of long running tests
                        2. Increase the allowed runtime before timeout
                        Hopefully this helps.
                        Best regards and thanks for keeping this thread alive!
                          @qistoph Well I’ve testing de CircleCI vs Travis.
                          For same Build
                          Failed: https://travis-ci.org/roramirez/MagicMirror/builds/234342109
                          Sucess: https://circleci.com/gh/roramirez/MagicMirror/6
                          • Q Offline
                            qistoph @roramirez
                            @roramirez
                            Except for one of the errors I think all can still be explained by my last post.
                              @qistoph said in Test suite for MagicMirror²:
                              Yes, you’re rigth. Can you help in this area?
                                Yay! After a long fight the test are passing in Travis CI
                                https://github.com/MichMich/MagicMirror/pull/953
                                  Cato Module Developer
                                  I’m trying to find some information on testing in Magic Mirror for devs/contributors but it’s (too) hard to find. I can’t find any related forum, it’s not mentioned in the “MagicMirror² Module Development Documentation”, and not directly mentioned in any README-ish files on GitHub.
                                  Of course, some of this can be deduced from the source code, but a small “Getting Started” guide would help more people getting … eh started. :-)
                                  I’m living in Visual Studio as my day job, but not so much with writing tests, so my knowledge of other tools are limited. What I need is some information on software requirements and where tests should be and how testing is done.
                                    roramirez Core Contributors @Cato
                                    @Cato Hi!, The documentation for tests are living only in test source ;) This is something. We need to an better documentation.
                                    Are you interested to do it? https://trello.com/c/UwqL27A3/29-add-documentation-of-testsuite
                                    I’m not a very good at writing documentation.
                                    But in short terms,
                                    The tests are living in tests directory, there two kind of test, unit and e2e.
                                    We are using mocha and spectron`, the last one is for the tests of e2e. For every e2e test is using a configuration file. When the test run load the configuration file and we check expected result of the MagicMirror instance in Electron mode.
                                    You can using the follow sentences to run testsuite
                                    • Unit test: npm run test:unit
                                    • E2e tests: npm run test:e2e
                                    • Unit + e2e: npm test
                                    If you can run especific test you need execute mocha from your path where is installed, in my case inside of MagicMirror directorio. Example of running the specific unit test for calendar functions.
                                    NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit/functions/calendar_spec.js
                                    Result:
                                      Functions into modules/default/calendar/calendar.js
                                        capFirst
                                          ✓ for 'rodrigo' should return 'Rodrigo'
                                          ✓ for '123m' should return '123m'
                                          ✓ for 'magic mirror' should return 'Magic mirror'
                                          ✓ for ',a' should return ',a'
                                          ✓ for 'ñandú' should return 'Ñandú'
                                        shorten
                                          ✓ for ' String with whitespace at the beginning that needs trimming' should return 'String with whit…'
                                          ✓ for 'long string that needs shortening' should return 'long string that…'
                                          ✓ for 'short string' should return 'short string'
                                          ✓ for 'long string with no maxLength defined' should return 'long string with no maxLength defined'
                                          ✓ should return an empty string if shorten is called with a non-string
                                          ✓ should not shorten the string if shorten is called with a non-number maxLength
                                          ✓ should wrap the string instead of shorten it if shorten is called with wrapEvents = true (with maxLength defined as 20)
                                          ✓ should wrap the string instead of shorten it if shorten is called with wrapEvents = true (without maxLength defined, default 25)
                                      13 passing (29ms)
                                    If need something is not clear let me know.
                                    • 2 / 3
