    Test suite for MagicMirror²
    Scheduled Pinned Locked Moved Upcoming Features
    42 Posts 5 Posters 54.8k Views 6 Watching
    • morozgrafixM Offline
      morozgrafix Moderator @roramirez
      @roramirez I’ve played a little with test suite and added basic test for clock module. Then I realized that if we want to test different config options for a given module we may need to have to create multiple configs, which may be challenging with current tests directory organization.
      Also I believe that process.env.MM_CONFIG_FILE = "tests/confs/config_name.js" line needs to be moved into before step (seems to work there or it can go into beforeEach if needed). Otherwise when running npm run test:e2e first config that gets picked up seems to persist throughout all of the tests and always used by the app.js.
      I was wondering if structure similar to this makes sense:
      tests
      ├── configs
      │   ├── env.js
      │   └── modules
      │   │   └── clock
      │   │   │   └── clock_12hr.js
      │   │   │   └── clock_24hr.js
      │   │   │   └── clock_analog.js
      │   │   └── helloworld
      │   │       └── helloworld.js
      ├── e2e
      │   ├── env_spec.js
      │   └── modules
      │       ├── clock_spec.js
      │       └── helloworld_spec.js
      ├── functions
      │   └── compare-version_spec.js
      └── global_vars
          └── root_path.js
      but this would involve changing app.use("/tests/confs", express.static(path.resolve(global.root_path + "/tests/confs"))); in the server.js to be somewhat dynamic and I’m not very familiar with express on how it can be done. I think that’s easily solved by just changing it to app.use("/tests/configs", express.static(path.resolve(global.root_path + "/tests/configs")));
        roramirez Core Contributors @morozgrafix
        @morozgrafix Seem good sense going to a refactor of the structure.
        I think we can take two way acord you mentioned.
        1.- Include your test for clock module with new format for name and respective directories
        2.- Do it the refactor to all tests that remain.
        I really like see how you resolve the multiples instances configuration in a one tests file.
        morozgrafixM 1 Reply Last reply Reply Quote 0
          @roramirez cool thanks. I have it all ready on my fork. Will submit PR for review.
          • Q Offline
            qistoph
            Two commits I’ve worked on for the testing.
            1. Check keys in the translation files. Produces errors currently, so I’ve added .skip.
              https://github.com/qistoph/MagicMirror/commit/123392c54934e49a397d586c1fb8dbcc4cc5d12b
            2. To prevent loading app.js from corrupting the Mocha test environment, I suggest to execute the app.js in a virtual environment. This can also serve as an example for future test cases where code needs to be executed in the global namespace.
              https://github.com/qistoph/MagicMirror/commit/cd8bee1371ffc6cce7b7bf44f85cd03705e4c1bd
            Any thoughts before I submit a PR?
            strawberry 3.141S R 2 Replies Last reply Reply Quote 1
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @qistoph
              @qistoph i like the idea of the sandbox
              is there a way to just warn instead of error for missing translation keys?
              Q 1 Reply Last reply Reply Quote 0
              • Q Offline
                qistoph @strawberry 3.141
                @strawberry-3.141
                How about this?
                https://github.com/qistoph/MagicMirror/commit/406ae4e8c37cbf7e31c89f5341d7715bacbcf0d2
                			try {
                				expect(fileKeys).to.deep.equal(baseKeys);
                			} catch(e) {
                				if (e instanceof chai.AssertionError) {
                					this.skip();
                				} else {
                					throw e;
                  roramirez Core Contributors @qistoph
                  @qistoph Nice work. Related with your first point there a discussion about translations of JSON file.
                  https://github.com/MichMich/MagicMirror/pull/679
                    Hi Guys,
                    Today I’ve playing with test suite I something going me crazy
                    I create the follow test
                    https://github.com/roramirez/MagicMirror/commit/88f1f6bbd4fe6d7f3b9391993d207c7b9ebfb2e9
                    Two check on same test case. On my enviroment ever but ever give me fail
                    smirror :: ~/MagicMirror ‹without-modules-test*› » ./node_modules/mocha/bin/mocha tests/e2e/without_modules.js
                      Check configuration without modules
                        ✓ Show the message create file config (83ms)
                        1) Show the message create file config 2
                      1 passing (6s)
                      1 failing
                      1) Check configuration without modules Show the message create file config 2:
                         Error: An element could not be located on the page using the given search parameters ("#module_2_helloworld .module-content").
                          at elements("#module_2_helloworld .module-content") - getText.js:18:17
                          at execute(, "isLoading", , "require") - api.js:350:19
                    I pushed a sample for shared with you and these are passing on Travis
                    https://travis-ci.org/roramirez/MagicMirror/jobs/200521954
                    Anybody can give me some light?
                    • Q Offline
                      qistoph
                      Weird… don’t see anything wrong with your code and it also runs fine on my machine…
                      Probably not really helpful, though, sorry
                        @qistoph I’ll test in other instance.
                        What S.O are you using?
                        • Q Offline
                          qistoph @roramirez
                          @roramirez what do you mean by “S.O”?
                            @qistoph Sorry, Spanish acronymous. I mean Operating System.
                            On the another hand. The same commit is passed in Travis on my personal forked but in the main Mich’s repository failed.
                            https://travis-ci.org/roramirez/MagicMirror/builds/200750569 (Pass)
                            https://travis-ci.org/MichMich/MagicMirror/builds/200750793 (Fail)
                            It’s so weird.
                            • Q Offline
                              qistoph @roramirez
                              @roramirez my tests ran on Ubuntu.
                              The failed build you’re linking has timeouts. That’s the issue I added to the Trello board. We could increase the timeout a bit and see if it happens again in the next days.
                              Ask Mich to re-run the failed build, he should be able to click that option in Travis, being the owner of the project. See if that fails again. That resolved it for me before.
                                @qistoph it’s pushed https://github.com/MichMich/MagicMirror/pull/716
                                  Hey guys,
                                  I pushed up a small refactoring for tests.
                                  https://github.com/MichMich/MagicMirror/pull/728
                                  This is a improvement for create new tests without unnecessary repeat inside of code.
                                  Something I wasnt think now is how can be integrate the case test created by @qistoph because this is set a app.path inside of test (It’s something I have not tried…yet)
                                  https://github.com/MichMich/MagicMirror/blob/e62df3b3b18cc98b65656194fa5baa53b9110fbc/tests/e2e/dev_console.js#L37
                                    A little update and I requests ideas and help
                                    Today I’m playing with a test for newsfeed module. Its not functional. I’m using the same MagicMirror as backend for response a feed (in the future can be good idea a fake server for testing purposes).
                                    The patch can you find on
                                    https://github.com/roramirez/MagicMirror/commit/db87f9e15b79827e947316c3ffba5b4ca49854b7
                                    The main case is the waiting the tests for module title and titles of news. There a delay around a 1 second after the “loading…” when is show in screen. Somebody have an idea to gets this test?
                                      roramirez Core Contributors @roramirez
                                      I fixed before mentioned https://github.com/roramirez/MagicMirror/commit/2a94ee55ccb8fa06f4d07c2a67307b5ed0a659a3
                                        The last build of today.
                                          I mention this here if someone can help
                                          If use moment-timezone for a test this fail
                                          • Fail in Travis: https://travis-ci.org/roramirez/MagicMirror/builds/220155902
                                          • Commit example: https://github.com/roramirez/MagicMirror/commit/05d7c9556e773bf2b941035953200ff327efb476
                                            Hi Guys, are you still alive?
                                            Sometimes the build failed, an example here
                                            https://travis-ci.org/MichMich/MagicMirror/jobs/227577643
                                            Someone have some idea how to fix this?
                                            cc @qistoph @strawberry-3-141 @morozgrafix
                                            • 2 / 3
