    WWW-iframe-ping fit web content into MM2 region
    4 Posts 3 Posters 974 Views 3 Watching
      dwburger
      I’m able to display web content using WWW-iframe-ping, but the content is too large so I’m only getting a sub-section of the webpage. How do I go about reducing the size of the web content to fit inside the frame I’ve created in the top_right region of my MM2? Thanks!
        sdetweil @dwburger
        @dwburger somehow u need to pass the size of the region to the web server sending the page IF it will adjust the size
        test on your pc with less than full screen browser
          dwburger @sdetweil
          @sdetweil Yes…when I open the URL I’m trying to display, it resizes nicely so all the information (in this case, data from a local weather station) is displayed to fit whatever screen size I choose. In other words, it’s responsive. I wonder if there are parameters I can add to the URL that will affect it’s display size??? I suppose I’ll need to experiment with that a bit.
          thgmirrorT 1 Reply Last reply Reply Quote 0
          • thgmirrorT Offline
            thgmirror @dwburger
            @dwburger Did you try a local html in the modules folder? There you can use iframe with a zoom-factor to get the content of the original-url. Afterwards show this using MM-SmartWebDisplay . The local webside must be stored in the modules-folder.
