    My 1st MagicMirror2
    21 Posts 10 Posters 24.1k Views 10 Watching
      sithlordhood @Cato
      @Cato It always triggers when it should. The sensor is quite powerful though in that it will work through stud walls… even with the sensitivity at the lowest setting! Not really a problem as the Mirror is downstairs in the house so when people are in the mirror is ‘on’ but come bed time and when the house is unoccupied the mirror turns off.
        sithlordhood @djdwayneanthony
        @djdwayneanthony Sure,
        Here is my config.js:
        /* Magic Mirror Config fILE
        • By Michael Teeuw http://michaelteeuw.nl
        • MIT Licensed.
        var config = {
        port: 8080,
        language: 'en',
        timeFormat: 24,
        units: 'metric',
        		module: 'alert',
        			welcome_message: 'Welcome, Magic Mirror boot-up successful!',
        		module: 'MMM-Remote-Control',
        //uncomment for url position: ‘top_left’,
        //uncomment {
        //for module: ‘MMM-Snow’,
        //s position: ‘fullscreen_above’,
        //n config: {
        //o flakeCount: 50,
        //w }
        module: ‘clock’,
        module: ‘calendar’,
        header: ‘The Hoods Calendar’,
        maximumEntries: 25,
        maximumNumberOfDays: 365,
        maxTitleLength: 25,
        animationSpeed: 0,
        fadePoint: 1,
        timeFormat: ‘absolute’,
        urgency: 7,
        symbol: ‘calendar’,
        url: ‘GOOGLE CALENDAR URL’
        module: ‘currentweather’,
        position: ‘top_right’,
        locationID: ‘2649692’, //ID from http://www.openweathermap.org
        appid: ‘API KEY’,
        module: ‘weatherforecast’,
        header: ‘Weather Forecast’,
        fadePoint: 1,
        appid: ‘API KEY’,
        showRainAmount: true,
        module: ‘MMM-NetworkScanner’,
        header: ‘Hood Family Mobile Phones’,
        devices: [
        { macAddress: “MAC1”, name: " Internet Router", icon: “wifi”},
        { macAddress: “MAC2”, name: “Simon”, icon: “mobile”},
        { macAddress: “MAC3”, name: “Emma”, icon: “mobile”},
        { macAddress: “MAC4”, name: “Jacob”, icon: “mobile”},
        { macAddress: “MAC5”, name: “Rhiannon”, icon: “mobile”},
        showUnknown: false,
        showOffline: true,
        keepAlive: 240,
        updateInterval: 10,
        module: ‘calendar_monthly’,
        fadeSpeed: 2,
        showHeader: ‘true’,
        cssStyle: ‘custom’, //block, clean, slate or custom
        updateDelay: 5,
        module: ‘newsfeed’,
        position: ‘bottom_bar’,
        showDescription: true,
        feeds: [
        title: “BBC News”,
        url: “http://feeds.bbci.co.uk/news/rss.xml?edition=uk”
        showSourceTitle: true,
        showPublishDate: true
        module: ‘MMM-Traffic’,
        classes: ‘dimmed medium’,
        api_key: ‘API KEY’,
        mode: ‘driving’,
        origin: ‘ORIGIN’,
        destination: ‘DESTINATION’,
        // arrival_time: ‘0730’, //optional, but needs to be in 24 hour time if used.
        route_name: ‘Simon - Home to Work’,
        changeColor: ‘true’,
        showGreen: ‘true’,
        limitYellow: 15, //Greater than 15% of journey time due to traffic
        limitRed: 30, //Greater than 30% of journey time due to traffic
        traffic_model: ‘pessimistic’,
        interval: 120000 //2 minutes
        classes: ‘dimmed medium’, //optional, default is ‘bright medium’, only applies to commute info not r$
        api_key: ‘API KEY’,
        mode: ‘driving’,
        origin: ‘ORIGIN’,
        route_name: ‘Emma - Home to Nursery’,
        showGreen: ‘true’,
        api_key: ‘API KEY’,
        mode: ‘driving’,
        origin: ‘ORIGIN’,
        route_name: ‘Home to Nana & Grandad Hoods’,
        showGreen: ‘true’,
        module: ‘mmm-systemtemperature’,
        classes: ‘small dimmed’,
        prependString: 'CPU Temp: ',
        updateInterval: 5000,
        animationSpeed: 0,
        module: ‘updatenotification’,
        if (typeof module !== ‘undefined’) {module.exports = config;}
        bolded text
        I have removed api keys, destinations, etc so anything in ITALICS you would require adding your own variable here as described in the modules.
        The Modules I used are:
        alert (default module)
        MMM-Remote-Control
        MMM-Snow (I only configure this ON during the holiday period!)
        clock (default module)
        calendar (default module)
        currentweather (default module)
        weatherforecast (default module)
        MMM-NetworkScanner
        calendar_monthly
        newsfeed (default module)
        MMM-Traffic (used three times, for different commutes)
        updatenotification (default module)
        • brobergB Offline
          broberg Project Sponsor
          You could remove the margins of the MM body, that way you would utilize more of the screen itself, since you have more mirror on the sides of the monitor :)
          S schlachtkreuzer6S 4 Replies Last reply Reply Quote 0
            sithlordhood @broberg
            @broberg I will look into this - will give me a little more room. Cheers!
              @djdwayneanthony Also here is my custom.css - it is only colour changes for the Weather forecast and not my work - copied from someone else’s post here…
              • Magic Mirror *
              • Custom CSS *
              • By Michael Teeuw http://michaelteeuw.nl *
              • MIT Licensed. *
              • Add any custom CSS below. *
              • Changes to this files will be ignored by GIT. *
              body {
              .dimmed {
              color: #666;
              .normal {
              color: #999’
              .bright {
              color: #fff;
              .brightb {
              color: #55acee;
              .currentweather .wi-sunrise {
              color: #ffd700;
              .currentweather .wi-sunset {
              color: #ffa500;
              .currentweather .wi-day-sunny {
              color: #ffff00;
              .currentweather .wi-night-showers {
              color: #55acee;
              .currentweather .wi-degrees {
              color: #415;
              .currentweather .wi-rain {
              color: #55acee;
              .currentweather .wi-showers {
              color: #55acee;
              color: #55acee;
              .currentweather .wi-night-alt-cloudy-windy {
              color: #aaa;
              .currentweather .wi-night-cloudy {
              color: #aaa;
              .currentweather .wi-cloudy {
              color: #aaa;
              .currentweather .wi-day-cloudy {
              color: #aaa;
              color: #aaa;
              .currentweather .wi-cloudy-windy {
              color: #aaa;
              color: #55acee;
              .currentweather .wi-thunderstorm {
              color: #ff00ff;
              .currentweather .wi-snow {
              color: #fff;
              .currentweather .wi-fog {
              color: #999;
              .currentweather .wi-night-clear {
              color: #fff;
              .currentweather .wi-night-rain {
              color: #55acee;
              .currentweather .wi-night-thunderstorm {
              color: #ff00ff;
              .currentweather .wi-night-snow {
              color: #fff;
              .weatherforecast .wi-sunrise {
              color: #ffd700;
              .weatherforecast .wi-sunset {
              color: #ffa500;
              .weatherforecast .wi-day-sunny {
              color: #ffff00;
              .weatherforecast .wi-night-showers {
              color: #55acee;
              .weatherforecast .wi-degrees {
              color: #415;
              .weatherforecast .wi-rain {
              color: #55acee;
              .weatherforecast .wi-showers {
              color: #55acee;
              color: #55acee;
              .weatherforecast .wi-night-alt-cloudy-windy {
              color: #aaa;
              .weatherforecast .wi-night-cloudy {
              color: #aaa;
              .weatherforecast .wi-cloudy {
              color: #aaa;
              .weatherforecast .wi-day-cloudy {
              color: #aaa;
              color: #aaa;
              .weatherforecast .wi-cloudy-windy {
              color: #aaa;
              color: #55acee;
              .weatherforecast .wi-thunderstorm {
              color: #ff00ff;
              .weatherforecast .wi-snow {
              color: #fff;
              .weatherforecast .wi-fog {
              color: #999;
              .weatherforecast .wi-night-clear {
              color: #fff;
              .weatherforecast .wi-night-rain {
              color: #55acee;
              .weatherforecast .wi-night-thunderstorm {
              color: #ff00ff;
              color: #fff;
                djdwayneanthony
                Legend! Will play about with this tomorrow! Thank you, and once again, well done!
                  This post is deleted!
                    sithlordhood @sithlordhood
                      @broberg Borderless Layout
                      Looks better - plus can get more calendar entries on the screen now! Thanks for the tip.
                      • brobergB Offline
                        broberg Project Sponsor @sithlordhood
                        @sithlordhood no probs! glad I could give useful tips :D
                        On my raspberry I also noticed my 1920 background didn’t display correctly, I had black borders around the workspace that cut off some graphics, so I followed this :
                        http://www.opentechguides.com/how-to/article/raspberry-pi/28/raspi-display-setting.html
                        And gained a couple of more pixels :) (ie I got the full 1920 resolution again)
                        • 3 / 3
