    Updatenotification bar doesn't show up
    8 Posts 2 Posters 2.1k Views 2 Watching
    • C
      ChrizZz
      Hey guys,
      I am struggling with the default module “updatenotification”. It doesn’t show the notification bar if there is an update for MM or one of the modules.
      The mm-out.log shows:
      [08.02.2021 18:55.19.771] [LOG]   Initializing new module helper ...
      [08.02.2021 18:55.19.773] [LOG]   Module helper loaded: updatenotification
      [08.02.2021 18:55.24.000] [LOG]   Connecting socket for: updatenotification
      There aren’t any log entries in mm-error.log
      My config has these lines for the module:
      			module: "updatenotification",
      			position: "top_bar",
      			classes: "always"
      I tried it without the classes line too.
      My MM version is 2.14.0
      //e: I used the “Troubleshooting” space and not the one in modules because I thought default modules would fit to this space better.
        sdetweil @ChrizZz
        @chrizzz the base has not been updated since 1/1/2021
        u would have to install outside modules and know that it was updated AFTER you installed it
        C 1 Reply Last reply
        • C
          ChrizZz @sdetweil
          @sdetweil sorry Sam, I think I don’t get your answer.
            sdetweil @ChrizZz
            @chrizzz there has been no update of mm. only happens once every quarter.
            also reports on modules not part of mm, but if u install a module, there would be no notification until that module was updated
            • C
              ChrizZz @sdetweil
              @sdetweil but I have modules with available updates and the update notification module doesn’t work for a few months. I did my last MM update without been notified. I did it just because it was weird to have such a long time without the update notification
                sdetweil @ChrizZz
                @chrizzz do a git --version on the commandine
                • C
                  ChrizZz @sdetweil
                  git version 2.20.1
                  • C
                    ChrizZz @ChrizZz
                    It works again. I think it was my mistake in the config based on the classes setting or compared with the carousel module.
