    MMM-Arduport trouble
    5 Posts 2 Posters 1.0k Views 2 Watching
    • G
      glorianneef
      Hello! So I am simply trying to run this module and I am just making my arduino code send the number “17” just to test. As you can see, when I run my python code, it receives this message correctly. Below is my config file
                  module: "MMM-ArduPort",
                  position: "bottom_right",
                  header: "MMM-ArduPort",
                      portname: "/dev/ttyACM0",
                      displayIcons: true,
                      showDescription: true,
                      hideLoading: true,
                      hideWaiting: true,
                      useColors: true,
                      sensors:
                              description: "LPG, Propane, Hydrogen",
                              maxValue: 19,
                              maxFormat: "({0} cm) TOO FAR",
                              highestValue: 30,
                              highestFormat: "({0} cm) FAR",
                              highValue: 15,
                              highFormat: "({0} cm) NORMAL",
                              lowValue: 10,
                              lowFormat: "({0} cm) CLOSE",
                              lowestValue: 5,
                              lowestFormat: "({0} cm) TOO CLOSE",
                              minValue: 0,
                              minFormat: "({0} cm) OK"
      As you can see when I start
      npm start dev
      I get a plethora of errors in which I have no idea how to fix. Any help would be super appreciated.
      2021-02-12-192811_1184x624_scrot[9806].png 2021-02-12-193400_1184x624_scrot[9807].png
      Also here is my arduino code (almost exactly like the one supplied by MMM-arduport git page:
      volatile int32_t m_counter = 0;
      bool WasStarted = false;
      static const char *pcMQ2Prefix = "[sensor:Timer:";
      static const char *pcPostfix = "]";
      void setup() {
        Serial.begin(9600);
        while(!Serial);
        Serial.println("[status:setup:starting]");
        int test = 1;
        m_counter = test;
        if(test > 1) {
          WasStarted = false;
          Serial.println("[status:setup:failed]");
          return;
        delay(3000);
        WasStarted = true;
        Serial.println("[status:setup:started]");
        delay(100);
      void loop() {
        //Serial.print(pcMQ2Prefix);
        //Serial.print(m_counter);
        //Serial.println(pcPostfix);
      Serial.println("[sensor:Timer:19]");
        if(m_counter % 3 == 0) {
          delay(1000);
          delay(2000);
        if(m_counter >= 60) m_counter = 0;
        m_counter++;
        delay(1000);
        sdetweil @glorianneef
        @glorianneef your sensors definition is incorrect
        it should be From
        https://github.com/Dentrax/MMM-ArduPort
        sensors:[
        // for each sensor
             description:"???????",
        • G
          glorianneef @sdetweil
          @sdetweil The only difference I see between that and mine is the extra
          added correct? I added the square brackets and I was still given the same errors
            @glorianneef ok can u show the errors there and any in the terminal window where u npm start
              @glorianneef also, there was an error when u ran the python script, to_node not found. did u install all the python dependencies?
