    Clock module not showing analog only digital
    3 Posts 2 Posters 671 Views 2 Watching
    • B
      Barmo
      Hi
      I reinstalled my mirror yesterday from scratch on a new memory card and I am not able to make it show the analog clock. No matter what I do in config.js, it shows a line with the date and the digital clock under. Clock module is the first module in config.js. My current config is this:
                              module: "clock",
                              displayType: "analog",
                              showDate: "false",
                              analogSize: "350px",
                              analogFace: "face-012",
      If I change the position parameter, it moves to the new location and still showing the digital clock.
      All other modules I use work as they should. Have anyone else experienced this?
      Thanks.
        sdetweil @Barmo
        @barmo all the settings u have for clock except position, need to be inside a config block
        position:"top",
        config:{
        also read and practice the content at the links in my signature below
        • B
          Barmo @sdetweil
          @sdetweil Thank you. I have been staring me blind on this. For some reason I forgot to add the config { } from my old configuration. You made my day. Thank you again :-)
