    raspberry pi issue
    3 Posts 3 Posters 996 Views 3 Watching
    • L Offline
      lpassamonte
      Hello, I’m not sure if anyone can help because it is an issue with my raspberry pi (I think) but its worth a shot.
      I have been working on my mirror for a while now mainly because I am busy and couldn’t finish it for a while, I’ve finally got it up and ready to use when I go to turn it on and all of the sudden it won’t load up. I first thought it was an issue with my VGA chord but I’m not sure it is anymore. When turning on it gets as far to the loading page with the four raspberries at the top then the screen goes black and the monitor I am using says “going into power save mode”.
      Ive been googling a lot of different things to try and find my issue but I haven’t been able to find anything that works. If anyone understands what may be going on and could help that would be fantastic, Thank you!
      Lexi
        sdetweil @lpassamonte
        @lpassamonte sadly, it sounds like u have an sd card corruption problem.
        i am not aware of any mechanism to fix this, short of a new card
          Mushu @lpassamonte
          @lpassamonte not sure if you’re even still here or trying this but I just joined so gonna necro the thread.
          Probably better for you to post rpi specific questions in the raspberry pi forums, and a quick google search found this thread that might solve your issue: https://www.raspberrypi.org/forums/viewtopic.php?t=5107
          Basically they had to edit the config file and enable a couple of HDMI boot options. Good luck!
