    Some issues with 2 modules
    9 Posts 3 Posters 2.5k Views 3 Watching
    • TechJak7000T
      TechJak7000
      I recently installed “bugsounet/MMM-GoogleAssistant + bugsounet/MMM-Assistant2Display” modules , and with a bit of struggle make it run.
      The issue is that when I ask for a YouTube video to be played, it tells me here is I found on YouTube, but nothing appears .
      I have followed the instructions by the dot.
      The second issue which has arrived with this is that at the bottom_left I have my “mmm-hue-lights” module which was showing the status of all my Philips Hue lights , has disappeared, although it’s in it’s place & show’s up at start and slightly displays the status but disappears.
      My gut feeling is that as I have approximately 15 modules on the front page which can be the cause of YouTube video not appearing and the disappearing of mmm-hue-light module.
      But as I said it’s just my feeling, it can some other technical issue with the code or anything else.
      I would appreciate any assistance.
      Here is my config.js :- https://gist.github.com/Cihangir7000/3d483671893beba5628162e428b2f867
      R AssassinsA 2 Replies Last reply Reply Quote 0
      • R
        raf @TechJak7000
        @techjak7000
        try youtube first and then what you are looking for
        example
        youtube …
        TechJak7000T 1 Reply Last reply Reply Quote 0
        • TechJak7000T
          TechJak7000 @raf
          @raf Absolutely agree with you, the issue is I get a replay back that “yes here is what I found” from Jarvis , but there is nothing which appears. That’s the dilemma, now my hue lights and Spotify modules don’t display nothing , the icon’s can be seen.
          Such frustration :o(
          • AssassinsA
            Assassins @TechJak7000
            @techjak7000
            The youtube is not working in denmark with MM (kodi rettigheder)
            • TechJak7000T
              TechJak7000 @Assassins
              @assassins Thank you so much for your reply ( Mange Tak ), hopefully it will work some time later on right ? or is it permanent ?
              AssassinsA 1 Reply Last reply Reply Quote 0
              • AssassinsA
                @techjak7000
                I dont now (Dejligt med en dansker mere) :-)
                • TechJak7000T
                  @assassins Det glæder mig også og finde folk med samme interesse her hjmme, men med hensyn til det YouTube sag, er der måske er der muligt for at få den til virk med VPN.
                  • AssassinsA
                    @techjak7000
                    Jeg opgav den, da jeg prøvede mange forskellige ting, det er meget få videoer den kan vise, og syntes den har svært ved at høre 100% hvad man siger, så pluslig kom den med madopskrifter. osv.
                    • TechJak7000T
                      TechJak7000
                      This post is deleted!
