    Not a module but a way to get info from Life360
    3 Posts 2 Posters 1.9k Views 4 Watching
    • J
      jtb11
      Re: Life 360 Module
      I was trying to find a way to make life360 display location info for my family and ended up making it work using the a python script to generate the info into an html page that I then use the MMM-SmartWebDisplay Module to grab the generated html. This gave me a bit more control over the updates as I update less during the night than the day. and I wanted the table reused elsewhere.
      What I used:
      • life360
      • python - to run the script
      • https://github.com/harperreed/life360-python - python life360 module the script below is the modified example
      • apache - to display the html generated
      • https://pypi.org/project/mapbox/ library to call mapbox
      • https://www.mapbox.com/ -free tier to translate the geocodes into place or street names
      Config.js
      MMM-SmartWebDisplay
                  module: 'MMM-SmartWebDisplay',
                  position: "middle_center",
                      url: ["http://192.168.1.106/life360.html"],
                      width: "700px",
                      height: "400px",
                      updateInterval: 4,
                      logDebug: false,
                      displayLastUpdate: false
      NOTE: for anyone else trying to figure out why MMM-SmartWebDisplay isnt working, if the default text in your html is black and your mirror background is black then nothing shows! the module is working it is just the text is invisible.
      I use crontab to run the script, e.g. this will run it every 3 minutes
      */3 * * * * /usr/bin/python /home/pi/dev/life360-python/checklife360.py >/var/www/html/life360.html
      This is my checklife360.py
      from life360 import life360
      import datetime
      from mapbox import Geocoder
      geocoder = Geocoder(access_token="insert your mapbox token here")
      if __name__ == "__main__":
          # basic authorization hash (base64 if you want to decode it and see the sekrets)
          # this is a googleable or sniffable value. i imagine life360 changes this sometimes.
          authorization_token = "cFJFcXVnYWJSZXRyZTRFc3RldGhlcnVmcmVQdW1hbUV4dWNyRUh1YzptM2ZydXBSZXRSZXN3ZXJFQ2hBUHJFOTZxYWtFZHI0Vg=="
          # your username and password (hope they are secure!)
          username = "life360username"
          password = "life360password"
          #instantiate the API
          api = life360(authorization_token=authorization_token, username=username, password=password)
          if api.authenticate():
              circles =  api.get_circles()
              id = circles[0]['id']
              circle = api.get_circle(id)
              print "<HEAD><link rel='stylesheet' href='main.css'></HEAD><BODY><TABLE>"
              for m in circle['members']:
                  bat = int(float(m['location']['battery']))
                  loclat = float(m['location']['latitude'])
                  loclng = float(m['location']['longitude'])
                  print "<TR><TD style='color:#ffff00;'>", m['firstName'] + "</TD>"
               # only call the geocoder if the name is not know this reduces the api calls
                  if m['location']['name']is not None:
                      print "<TD>&nbsp;</TD><TD style='color:#ffff00;'>" , m['location']['name'] + "</TD>"
                  else:
                      response = geocoder.reverse(lon=loclng, lat=loclat)
                      features = response.geojson()['features']
                      addr1='{place_name}: {id}'.format(**features[0]).split(",")
                      addr2='{place_name}: {id}'.format(**features[1]).split(",")
                      print "<TD>&nbsp;</TD><TD style='color:#3383FF;'>" + addr1[0] + ", " +  addr2[1] + "</TD>"
                  if bat > 40:
                      print "<TD style='font-size: 15px;color:#00FF00;'>" , "{:.{}f}".format(float(m['location']['battery']),0) +"%</TD>"
                  elif bat > 21:
                      print "<TD style='font-size: 15px;color:#FFFF00;'>" , "{:.{}f}".format(float(m['location']['battery']),0) +"%</TD>"
                  else:
                      print "<TD style='font-size: 15px;color:#FF00FF;'>" , "{:.{}f}".format(float(m['location']['battery']),0) +"%</TD>"
                  print "</TR>"
              print "</TABLE></BODY>"
          else:
              print "Error authenticating"
      Hope this helps someone else.
      • R
        ryanbuckner @jtb11
        @jtb11 I’m getting an error
        ImportError: cannot import name 'life360' from partially initialized module 'life360'
        • J
          jtb11 @ryanbuckner
          @ryanbuckner said in Not a module but a way to get info from Life360:
          ImportError: cannot import name ‘life360’ from partially initialized module ‘life360’
          Do you find a solution for this?
          Also I modified the location as internationalcharacters were breaking the location name display
          change
          if m[‘location’][‘name’]is not None:
          print “ ” , m[‘location’][‘name’] + “”
          To:
                      locname = m['location']['name'].encode('ascii', 'ignore').decode('ascii')
                      print ("<TD>&nbsp;</TD><TD style='color:#ffff00;'>" , locname + "</TD>")
