    pm2 doesnt work with crontab
    45 Posts 8 Posters 19.1k Views 6 Watching
    • K
      keineAhnung123
      Hello,
      Im trying to restart my MM every day in the night so i want to use a crontab.
      Might be easy:
      sudo crontab -e
      and add
      59 23 * * * pm2 restart mm
      But that doesnt work.
      The crontab seems to work:
      Feb 27 13:37:01 raspberrypi CRON[3581]: (root) CMD (pm2 restart mm)
      And i did a pm2 flush before and after the crontab did its job there is nothing in the log:
      pi@raspberrypi:~ $ pm2 logs --lines=100
      [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 100 lines:
      /home/pi/.pm2/logs/mm-error.log last 100 lines:
      /home/pi/.pm2/logs/mm-out.log last 100 lines:
      0|mm       | [27.02.2021 13:38.28.339] [INFO]  Newsfeed-Fetcher: Broadcasting 39 items.
      so it seems that pm2 didnt do anything.
      Next try after some online research:
      pi@raspberrypi:~ $ which node
      /home/pi/.config/nvm/versions/node/v10.23.0/bin/node
      pi@raspberrypi:~ $ which pm2
      /home/pi/.config/nvm/versions/node/v10.23.0/bin/pm2
      i changed the crontab to
      1 14 * * * /home/pi/.config/nvm/versions/node/v10.23.0/bin/node /home/pi/.config/nvm/versions/node/v10.23.0/bin/pm2 restart mm
      (1 14 is for testing)
      It still doesnt work: no output in pm2 log.
      Does anyone have an idea?
      S AssassinsA 2 Replies Last reply Reply Quote 0
        sdetweil @keineAhnung123
        @keineahnung123 u need to run pm2 as the user that did the save and where mm was running. it cannot be rootScreenshot_20210227-074511_Chrome.jpg
        you also create a user specific crontab in /var/spool/cron
        user needs to own the file, then username is not required on the contab entries themselves
        Each user, including root, can have a cron file. These files don't exist by default, but can be created in the /var/spool/cron directory using the crontab -e command that's also
        • K
          keineAhnung123 @sdetweil
          @sdetweil Thanks.
          With
          sudo nano /etc/crontab
          and
          30 16   * * *   pi      /home/pi/.config/nvm/versions/node/v10.23.0/bin/node /home/pi/.config/nvm/versions/node/v10.23.0/bin/pm2 stop mm
          it seems to work :)
            @keineahnung123 i don’t think u need those paths now
            • K
              45 16   * * *   pi      pm2 stop mm
              doesnt work. I have to set the paths.
              I think there went something wrong when i upgraded to buster.
              I had a shellscript with
              cd ~/MagicMirror && npm start
              which worked fine and after the upgrade to buster i have to use
              cd ~/MagicMirror && /home/pi/.config/nvm/versions/node/v10.23.0/bin/npm start
              otherwise it says “npm: not found”
              Same seems to be with crontab…
                @keineahnung123 looks like u need to reinstall nvm
                • K
                  @sdetweil said in pm2 doesnt work with crontab:
                  nvm or npm?
                    @keineahnung123 nvm
                    • AssassinsA
                      Assassins @keineAhnung123
                      @keineahnung123
                      Hello, i Can send you a script om monday, where you make backup to a small .img and where is restart you MagicMirror on the same time.
                      plainbrokeP 1 Reply Last reply Reply Quote 0
                      • plainbrokeP
                        plainbroke @Assassins
                        @Assassins
                        I would like to see this script. Please.
                        • plainbrokeP
                          plainbroke
                          This is all I use in my crontab -e
                          15 07 * * * pm2 start mm
                          30 21 * * * pm2 stop all
                          Shuts MM down at 9:30 pm
                          Starts MM backup at 7:15 am
                          EVERYDAY.
                          I have a Black background color and the bar at the bottom using black background which makes it look like the screen is off basically.
                          That way it doesn’t flood the room with light at night.
                          Also less read / writes to the ssd drive I use for my MM.
                          • plainbrokeP
                            plainbroke @plainbroke
                            My old crontab does not work in debian 12 aka bookworm
                            Is there something i need to add to it to get it to work again?
                            Really liked how it worked and the fact that I was getting a fresh restart of mm every morning…
                            Tried this too.
                            15 07 * * * pi  pm2 start mm
                            30 21 * * * pi  pm2 stop all
                              sdetweil @plainbroke
                              @plainbroke what userid did the pm2 jobs get created under?
                              • plainbrokeP
                                plainbroke @sdetweil
                                pi is my user. I know not very original or safe but it is on a closed network.
                                that is why I tried the pi user in the crontab.
                                and it shows up when I do crontab -l.
                                So I think it is setup under pi correctly.
                                Do I need to do it as root sudo crontab -e and use pi or root as the user?
                                S karsten13K 2 Replies Last reply Reply Quote 0
                                  @plainbroke no. what fo the pm2 logs show?
                                  pm2 logs --lines=xxx
                                  xxx is number of most recent lines, default 15
                                  • karsten13K
                                    karsten13 @plainbroke
                                    @plainbroke
                                    you can do cron restart with pm2 too, see https://pm2.keymetrics.io/docs/usage/restart-strategies/
                                    • plainbrokeP
                                      This post is deleted!
                                        @plainbroke i mean after cron trying to start
                                        pm2
                                        set a cron entry for an hour from now stop MagicMirror and flush the logs
                                        pm2 stop all
                                        pm2 flush
                                        see what the logs say then
                                          sdetweil @karsten13
                                          @karsten13 yes, but he wants stop and start
                                          • plainbrokeP
                                            Got ya, I miss understood before.
                                            Running and waiting for results now…
                                            Finally got results useing the proper path.
                                            You can mark this resolved.
                                            • 1 / 3
