    pm2 doesnt work with crontab
    45 Posts 8 Posters 20.3k Views 6 Watching
    • AssassinsA
      Assassins @keineAhnung123
      @keineahnung123
      Hello, i Can send you a script om monday, where you make backup to a small .img and where is restart you MagicMirror on the same time.
      plainbrokeP 1 Reply Last reply
      • plainbrokeP
        plainbroke @Assassins
        @Assassins
        I would like to see this script. Please.
        • plainbrokeP
          plainbroke
          This is all I use in my crontab -e
          15 07 * * * pm2 start mm
          30 21 * * * pm2 stop all
          Shuts MM down at 9:30 pm
          Starts MM backup at 7:15 am
          EVERYDAY.
          I have a Black background color and the bar at the bottom using black background which makes it look like the screen is off basically.
          That way it doesn’t flood the room with light at night.
          Also less read / writes to the ssd drive I use for my MM.
          • plainbrokeP
            plainbroke @plainbroke
            My old crontab does not work in debian 12 aka bookworm
            Is there something i need to add to it to get it to work again?
            Really liked how it worked and the fact that I was getting a fresh restart of mm every morning…
            Tried this too.
            15 07 * * * pi  pm2 start mm
            30 21 * * * pi  pm2 stop all
              sdetweil @plainbroke
              @plainbroke what userid did the pm2 jobs get created under?
              • plainbrokeP
                plainbroke @sdetweil
                pi is my user. I know not very original or safe but it is on a closed network.
                that is why I tried the pi user in the crontab.
                and it shows up when I do crontab -l.
                So I think it is setup under pi correctly.
                Do I need to do it as root sudo crontab -e and use pi or root as the user?
                S karsten13K 2 Replies Last reply
                  @plainbroke no. what fo the pm2 logs show?
                  pm2 logs --lines=xxx
                  xxx is number of most recent lines, default 15
                  • karsten13K
                    karsten13 @plainbroke
                    @plainbroke
                    you can do cron restart with pm2 too, see https://pm2.keymetrics.io/docs/usage/restart-strategies/
                    • plainbrokeP
                        @plainbroke i mean after cron trying to start
                        pm2
                        set a cron entry for an hour from now stop MagicMirror and flush the logs
                        pm2 stop all
                        pm2 flush
                        see what the logs say then
                          sdetweil @karsten13
                          @karsten13 yes, but he wants stop and start
                          • plainbrokeP
                            Got ya, I miss understood before.
                            Running and waiting for results now…
                            Finally got results useing the proper path.
                            You can mark this resolved.
                              @plainbroke how long til it might trigger?
                              • plainbrokeP
                                From that post about an hour. and it was supposed to trigger this morning around 6:30 am.
                                It did not and it did not leave anything in the logs since last night when I pm2 stop all then pm2 flush. around 8:30 pm .
                                So that means cron job did nothing with pm2 over night
                                I have been experimenting so there are a couple different job lines.
                                I really expected something in the log. But this is all I get.
                                pi@MM:~ $ pm2 logs --lines=100
                                My Crontab on 2 different MM setups. I get the same nothing on both.
                                Both are running Bookworm and MM 2.3.1
                                05 20 * * * pi /usr/local/bin/pm2 start mm
                                30 21 * * * pi pm2 stop mm
                                05 20 * * * root /usr/local/bin/pm2 start mm
                                15 07 * * * root pm2 start mm
                                30 21 * * * root pm2 stop mm
                                C 1 Reply Last reply
                                  chrisfr1976 @plainbroke
                                  @plainbroke
                                  try this:
                                  crontab -e with connected user:
                                  05 20 * * * /usr/bin/pm2 start mm
                                  15 07 * * * /usr/bin/pm2 start mm
                                  30 21 * * * /usr/bin/pm2 stop mm
                                  • sudo crontab -e is not necessary.
                                  • I do not understand the start at 20:05 (first line)
                                  • my pm2 is in /usr/bin
                                  • always use full path in crontab
                                  If you’re not sure where PM2 is you can use find / -iname pm2 in the console. Important is the full path in crontab.
                                  /home/chris/.nvm/versions/node/v22.9.0/lib/node_modules/pm2/pm2 would be an alternative for me.
                                  Regards, Chris.
                                  • plainbrokeP
                                    plainbroke @chrisfr1976
                                    @chrisfr1976 said in pm2 doesnt work with crontab:
                                    find / -iname pm2
                                    /usr/local/bin/pm2
                                    /usr/local/lib/node_modules/pm2
                                    /usr/local/lib/node_modules/pm2/bin/pm2
                                    /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
                                    /usr/local/lib/node_modules/pm2/pm2
                                    /home/pi/MagicMirror/node_modules/.bin/pm2
                                    /home/pi/MagicMirror/node_modules/pm2
                                    /home/pi/MagicMirror/node_modules/pm2/bin/pm2
                                    /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
                                    /home/pi/MagicMirror/node_modules/pm2/pm2
                                    Which is the true one and one to use?
                                      @plainbroke
                                      Then use this:
                                      /usr/local/bin/pm2
                                      Regards, Chris.
                                      • plainbrokeP
                                        @chrisfr1976
                                        Thank you both for the help.
                                        /usr/local/bin/pm2 restart mm
                                        worked so I set it up to stop now and if (fingers crossed) works.
                                        I am golden.
                                        Wonder why I never had to use the full path before?
                                        Maybe my pm2 path was /home/pi/pm2 before.
                                        Doesn’t really matter as long as it works, I am a happy camper.
                                        It works.
                                        Thank you so much… I will mark this solved.
                                        Well I would if I could… strange.
                                        By the way " which pm2 " shows the path that I needed to use in crontab -e
                                          @plainbroke awesome
                                          i should have remembered the path problem
                                          • plainbrokeP
                                            Did the new MM and or trixie change the way crontab works? Mine has stopped working since the update to 2.33. I tried again tonight and will see if the changes work or not… also my mm.json file quit working. Hind sight is 20/20 should have left well enough alone…
