    pm2 doesnt work with crontab
    45 Posts 8 Posters 20.3k Views 6 Watching
    • plainbrokeP
      plainbroke @sdetweil
      pi is my user. I know not very original or safe but it is on a closed network.
      that is why I tried the pi user in the crontab.
      and it shows up when I do crontab -l.
      So I think it is setup under pi correctly.
      Do I need to do it as root sudo crontab -e and use pi or root as the user?
      S karsten13K 2 Replies Last reply
        sdetweil @plainbroke
        @plainbroke no. what fo the pm2 logs show?
        pm2 logs --lines=xxx
        xxx is number of most recent lines, default 15
        plainbrokeP 1 Reply Last reply
        • karsten13K
          karsten13 @plainbroke
          @plainbroke
          you can do cron restart with pm2 too, see https://pm2.keymetrics.io/docs/usage/restart-strategies/
          • plainbrokeP
              @plainbroke i mean after cron trying to start
              pm2
              set a cron entry for an hour from now stop MagicMirror and flush the logs
              pm2 stop all
              pm2 flush
              see what the logs say then
                sdetweil @karsten13
                @karsten13 yes, but he wants stop and start
                • plainbrokeP
                  Got ya, I miss understood before.
                  Running and waiting for results now…
                  Finally got results useing the proper path.
                  You can mark this resolved.
                    @plainbroke how long til it might trigger?
                    • plainbrokeP
                      From that post about an hour. and it was supposed to trigger this morning around 6:30 am.
                      It did not and it did not leave anything in the logs since last night when I pm2 stop all then pm2 flush. around 8:30 pm .
                      So that means cron job did nothing with pm2 over night
                      I have been experimenting so there are a couple different job lines.
                      I really expected something in the log. But this is all I get.
                      pi@MM:~ $ pm2 logs --lines=100
                      My Crontab on 2 different MM setups. I get the same nothing on both.
                      Both are running Bookworm and MM 2.3.1
                      05 20 * * * pi /usr/local/bin/pm2 start mm
                      15 07 * * * pi pm2 start mm
                      30 21 * * * pi pm2 stop mm
                      05 20 * * * root /usr/local/bin/pm2 start mm
                      15 07 * * * root pm2 start mm
                      30 21 * * * root pm2 stop mm
                      C 1 Reply Last reply
                        chrisfr1976 @plainbroke
                        @plainbroke
                        try this:
                        crontab -e with connected user:
                        05 20 * * * /usr/bin/pm2 start mm
                        15 07 * * * /usr/bin/pm2 start mm
                        30 21 * * * /usr/bin/pm2 stop mm
                        • sudo crontab -e is not necessary.
                        • I do not understand the start at 20:05 (first line)
                        • my pm2 is in /usr/bin
                        • always use full path in crontab
                        If you’re not sure where PM2 is you can use find / -iname pm2 in the console. Important is the full path in crontab.
                        /home/chris/.nvm/versions/node/v22.9.0/lib/node_modules/pm2/pm2 would be an alternative for me.
                        Regards, Chris.
                        • plainbrokeP
                          plainbroke @chrisfr1976
                          @chrisfr1976 said in pm2 doesnt work with crontab:
                          find / -iname pm2
                          /usr/local/bin/pm2
                          /usr/local/lib/node_modules/pm2
                          /usr/local/lib/node_modules/pm2/bin/pm2
                          /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
                          /usr/local/lib/node_modules/pm2/pm2
                          /home/pi/MagicMirror/node_modules/.bin/pm2
                          /home/pi/MagicMirror/node_modules/pm2
                          /home/pi/MagicMirror/node_modules/pm2/bin/pm2
                          /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
                          /home/pi/MagicMirror/node_modules/pm2/pm2
                          Which is the true one and one to use?
                            @plainbroke
                            Then use this:
                            /usr/local/bin/pm2
                            Regards, Chris.
                            • plainbrokeP
                              @chrisfr1976
                              Thank you both for the help.
                              /usr/local/bin/pm2 restart mm
                              worked so I set it up to stop now and if (fingers crossed) works.
                              I am golden.
                              Wonder why I never had to use the full path before?
                              Maybe my pm2 path was /home/pi/pm2 before.
                              Doesn’t really matter as long as it works, I am a happy camper.
                              It works.
                              Thank you so much… I will mark this solved.
                              Well I would if I could… strange.
                              By the way " which pm2 " shows the path that I needed to use in crontab -e
                                @plainbroke awesome
                                i should have remembered the path problem
                                • plainbrokeP
                                  Did the new MM and or trixie change the way crontab works? Mine has stopped working since the update to 2.33. I tried again tonight and will see if the changes work or not… also my mm.json file quit working. Hind sight is 20/20 should have left well enough alone…
                                    @plainbroke I do not know
                                    Sorry, I have to ask, you DID use a new sd card, right?
                                    What does /var/log/syslog say about the crontab execution
                                    Did you use crontab -e
                                    Or sudo crontab -e
                                    1st is run as user who executed the crontab command
                                    2nd is run as root
                                    • plainbrokeP
                                      Using NVMe disk 256gb smallest I had on hand. 3 of them are exhibiting the same issues. I did try going back to Bookworm and I am still getthing a blank screen after a while. I ran npm run config:check it says all is good in the config.js ////
                                      I am currently reloading from scratch.
                                      Which OS is better for the 2.33 MM? 32 or 64 bit?
                                      Wondering if I was using 32 bit and now the 64 bit is messing with me… So dang many things can mess with these little devices.
                                      I only use crontab -e, should I try sudo crontab -e
                                        @plainbroke no, without sudo is best
                                        Maybe pm2 isn’t in the path when crontab fires
                                        Check the syslog for crontab errors
                                        32 bit is about to be trouble.
                                        The latest nodejs version, 24, has dropped builds for 32 bit
                                        • plainbrokeP
                                          Thanks for the info I almost pulled down 32 bit.
                                          It has been interesting to say the least going to trixie.
                                          Turns out my problem was a failed NVMe drive.
                                          I thought those things where supposed to last for a LONG long time…
                                          I did get crontab -e to work with trixie and MM 2.33 not a fun ride, but entertaining. I finally learned how to use bash to make batch style files…
                                          So not a complete loss of time…
                                            @plainbroke technology is SOOOO much fun! Simple, til it’s not!
                                            Thanks for the feedback. Others will ask, I’m sure they could use your help!
                                            • 2 / 3
