    pm2 doesnt work with crontab
    45 Posts 8 Posters 18.5k Views 6 Watching
      sdetweil @karsten13
      @karsten13 yes, but he wants stop and start
      • plainbrokeP Offline
        plainbroke @sdetweil
        Got ya, I miss understood before.
        Running and waiting for results now…
        Finally got results useing the proper path.
        You can mark this resolved.
          sdetweil @plainbroke
          @plainbroke how long til it might trigger?
            From that post about an hour. and it was supposed to trigger this morning around 6:30 am.
            It did not and it did not leave anything in the logs since last night when I pm2 stop all then pm2 flush. around 8:30 pm .
            So that means cron job did nothing with pm2 over night
            I have been experimenting so there are a couple different job lines.
            I really expected something in the log. But this is all I get.
            pi@MM:~ $ pm2 logs --lines=100
            My Crontab on 2 different MM setups. I get the same nothing on both.
            Both are running Bookworm and MM 2.3.1
            05 20 * * * pi /usr/local/bin/pm2 start mm
            15 07 * * * pi pm2 start mm
            30 21 * * * pi pm2 stop mm
            05 20 * * * root /usr/local/bin/pm2 start mm
            15 07 * * * root pm2 start mm
            30 21 * * * root pm2 stop mm
              chrisfr1976 @plainbroke
              @plainbroke
              try this:
              crontab -e with connected user:
              05 20 * * * /usr/bin/pm2 start mm
              15 07 * * * /usr/bin/pm2 start mm
              30 21 * * * /usr/bin/pm2 stop mm
              • sudo crontab -e is not necessary.
              • I do not understand the start at 20:05 (first line)
              • my pm2 is in /usr/bin
              • always use full path in crontab
              If you’re not sure where PM2 is you can use find / -iname pm2 in the console. Important is the full path in crontab.
              /home/chris/.nvm/versions/node/v22.9.0/lib/node_modules/pm2/pm2 would be an alternative for me.
              Regards, Chris.
                plainbroke @chrisfr1976
                @chrisfr1976 said in pm2 doesnt work with crontab:
                find / -iname pm2
                /usr/local/bin/pm2
                /usr/local/lib/node_modules/pm2
                /usr/local/lib/node_modules/pm2/bin/pm2
                /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
                /usr/local/lib/node_modules/pm2/pm2
                /home/pi/MagicMirror/node_modules/.bin/pm2
                /home/pi/MagicMirror/node_modules/pm2
                /home/pi/MagicMirror/node_modules/pm2/bin/pm2
                /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
                /home/pi/MagicMirror/node_modules/pm2/pm2
                Which is the true one and one to use?
                  @plainbroke
                  Then use this:
                  /usr/local/bin/pm2
                  Regards, Chris.
                  plainbrokeP 1 Reply Last reply Reply Quote 1
                    @chrisfr1976
                    Thank you both for the help.
                    /usr/local/bin/pm2 restart mm
                    worked so I set it up to stop now and if (fingers crossed) works.
                    I am golden.
                    Wonder why I never had to use the full path before?
                    Maybe my pm2 path was /home/pi/pm2 before.
                    Doesn’t really matter as long as it works, I am a happy camper.
                    It works.
                    Thank you so much… I will mark this solved.
                    Well I would if I could… strange.
                    By the way " which pm2 " shows the path that I needed to use in crontab -e
                      @plainbroke awesome
                      i should have remembered the path problem
                        Did the new MM and or trixie change the way crontab works? Mine has stopped working since the update to 2.33. I tried again tonight and will see if the changes work or not… also my mm.json file quit working. Hind sight is 20/20 should have left well enough alone…
                          @plainbroke I do not know
                          Sorry, I have to ask, you DID use a new sd card, right?
                          What does /var/log/syslog say about the crontab execution
                          Did you use crontab -e
                          Or sudo crontab -e
                          1st is run as user who executed the crontab command
                          2nd is run as root
                            Using NVMe disk 256gb smallest I had on hand. 3 of them are exhibiting the same issues. I did try going back to Bookworm and I am still getthing a blank screen after a while. I ran npm run config:check it says all is good in the config.js ////
                            I am currently reloading from scratch.
                            Which OS is better for the 2.33 MM? 32 or 64 bit?
                            Wondering if I was using 32 bit and now the 64 bit is messing with me… So dang many things can mess with these little devices.
                            I only use crontab -e, should I try sudo crontab -e
                              @plainbroke no, without sudo is best
                              Maybe pm2 isn’t in the path when crontab fires
                              Check the syslog for crontab errors
                              32 bit is about to be trouble.
                              The latest nodejs version, 24, has dropped builds for 32 bit
                                Thanks for the info I almost pulled down 32 bit.
                                It has been interesting to say the least going to trixie.
                                Turns out my problem was a failed NVMe drive.
                                I thought those things where supposed to last for a LONG long time…
                                I did get crontab -e to work with trixie and MM 2.33 not a fun ride, but entertaining. I finally learned how to use bash to make batch style files…
                                So not a complete loss of time…
                                  @plainbroke technology is SOOOO much fun! Simple, til it’s not!
                                  Thanks for the feedback. Others will ask, I’m sure they could use your help!
                                    Ok crontab -e worked last night to shutdown MM. So the pm2 stop all worked.
                                    BUT this morning the pm2 restart mm did nothing.
                                    I used find to get these:
                                    /usr/local/bin/pm2
                                    ANY idea on which one would work better.?
                                    Here is my current crontab -e
                                    # Turn off display at 9pm
                                    00 21 * * 0-6 /usr/local/bin/pm2 stop all >/dev/null >2&1
                                    # Turn on screen Monday - Friday at 6:45 am
                                    45 06 * * 1-5 /usr/local/bin/pm2 start mm >/dev/null >2&1
                                    # Turn on screen Saturday - Sunday at 7:30 am
                                    30 07 * * 6,0 /usr/local/bin/pm2 start mm >/dev/null >2&1
                                    S mumblebajM 3 Replies Last reply Reply Quote 0
                                      @plainbroke which one, if any , are in the path
                                      Are they all executable?
                                      ls -laF
                                      Will give you the permissions mask
                                      Are any of them links to another?
                                      What changed?
                                      /usr/local/bin/pm2
                                      Should be the one
                                        @plainbroke also look in /var/log/syslog
                                        To find the logging of the execute at the time it should fire
                                          Weird, I do not have /var/log/syslog.
                                          Even did a find for it nothing, popped up…
                                          pi@Pixie:~ $ ls -laF
                                          total 348
                                          drwx------ 15 pi   pi     4096 Nov 10 15:36 ./
                                          drwxr-xr-x  3 root root   4096 Sep 30 19:18 ../
                                          -rw-------  1 pi   pi     9080 Nov 10 13:17 .bash_history
                                          -rw-r--r--  1 pi   pi      220 Sep 30 19:06 .bash_logout
                                          -rw-r--r--  1 pi   pi     3523 Sep 30 19:06 .bashrc
                                          drwx------ 13 pi   pi     4096 Nov  7 18:22 .cache/
                                          drwx------ 22 pi   pi     4096 Nov  8 12:57 .config/
                                          drwx------  3 pi   pi     4096 Nov  7 17:49 .dbus/
                                          drwxrwxr-x  2 pi   pi     4096 Sep 30 19:17 Desktop/
                                          drwx------  2 pi   pi     4096 Nov  7 23:11 Documents/
                                          -rw-rw-r--  1 pi   pi        0 Nov  7 20:00 .gitconfig
                                          -rw-rw-r--  1 pi   pi       81 Nov  7 18:24 .gtkrc-2.0
                                          -rw-rw-r--  1 pi   pi   222126 Oct 27 18:52 install.log
                                          drwx------  4 pi   pi     4096 Sep 30 19:18 .local/
                                          drwxrwxr-x 16 pi   pi     4096 Nov  8 12:54 MagicMirror/
                                          -rwxrwxrwx  1 pi   pi      320 Jun 12  2022 mm.json*
                                          -rwxrwxrwx  1 pi   pi       38 Jul 16  2023 mm.sh*
                                          drwx------  4 pi   pi     4096 Nov  6 21:05 .mozilla/
                                          drwxrwxr-x  4 pi   pi     4096 Oct 27 18:30 .npm/
                                          drwx------  3 pi   pi     4096 Oct 27 18:52 .pki/
                                          drwxrwxr-x  5 pi   pi     4096 Nov  9 17:24 .pm2/
                                          -rw-r--r--  1 pi   pi      807 Sep 30 19:06 .profile
                                          -rw-rw-r--  1 pi   pi       66 Oct 27 19:22 .selected_editor
                                          drwxrwxr-x  4 pi   pi     4096 Nov 10 15:43 shared/
                                          -rw-r--r--  1 pi   pi        0 Sep 30 19:18 .sudo_as_admin_successful
                                          drwx------  3 pi   pi     4096 Nov  5 17:30 .vnc/
                                          -rw-------  1 pi   pi       50 Nov  9 17:24 .Xauthority
                                          -rw-------  1 pi   pi     8238 Nov  9 19:32 .xsession-errors
                                          -rw-------  1 pi   pi     7945 Nov  9 17:24 .xsession-errors.old
                                          • mumblebajM Offline
                                            mumblebaj Module Developer @plainbroke
                                            @plainbroke Instead of piping the output to a blackhole, maybe pipe it to a logfile which you can interrogate to see why the pm2 start is not working?
                                            • 2 / 3
