    pm2 doesnt work with crontab
    45 Posts 8 Posters 18.0k Views 6 Watching
    • plainbrokeP Offline
      plainbroke @sdetweil
        sdetweil @plainbroke
        @plainbroke i mean after cron trying to start
        pm2
        set a cron entry for an hour from now stop MagicMirror and flush the logs
        pm2 stop all
        pm2 flush
        see what the logs say then
          sdetweil @karsten13
          @karsten13 yes, but he wants stop and start
            Got ya, I miss understood before.
            Running and waiting for results now…
            Finally got results useing the proper path.
            You can mark this resolved.
              @plainbroke how long til it might trigger?
                From that post about an hour. and it was supposed to trigger this morning around 6:30 am.
                It did not and it did not leave anything in the logs since last night when I pm2 stop all then pm2 flush. around 8:30 pm .
                So that means cron job did nothing with pm2 over night
                I have been experimenting so there are a couple different job lines.
                I really expected something in the log. But this is all I get.
                pi@MM:~ $ pm2 logs --lines=100
                My Crontab on 2 different MM setups. I get the same nothing on both.
                Both are running Bookworm and MM 2.3.1
                05 20 * * * pi /usr/local/bin/pm2 start mm
                15 07 * * * pi pm2 start mm
                30 21 * * * pi pm2 stop mm
                05 20 * * * root /usr/local/bin/pm2 start mm
                15 07 * * * root pm2 start mm
                30 21 * * * root pm2 stop mm
                  chrisfr1976 @plainbroke
                  @plainbroke
                  try this:
                  crontab -e with connected user:
                  05 20 * * * /usr/bin/pm2 start mm
                  15 07 * * * /usr/bin/pm2 start mm
                  30 21 * * * /usr/bin/pm2 stop mm
                  • sudo crontab -e is not necessary.
                  • I do not understand the start at 20:05 (first line)
                  • my pm2 is in /usr/bin
                  • always use full path in crontab
                  If you’re not sure where PM2 is you can use find / -iname pm2 in the console. Important is the full path in crontab.
                  /home/chris/.nvm/versions/node/v22.9.0/lib/node_modules/pm2/pm2 would be an alternative for me.
                  Regards, Chris.
                    plainbroke @chrisfr1976
                    @chrisfr1976 said in pm2 doesnt work with crontab:
                    find / -iname pm2
                    /usr/local/bin/pm2
                    /usr/local/lib/node_modules/pm2
                    /usr/local/lib/node_modules/pm2/bin/pm2
                    /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
                    /usr/local/lib/node_modules/pm2/pm2
                    /home/pi/MagicMirror/node_modules/.bin/pm2
                    /home/pi/MagicMirror/node_modules/pm2
                    /home/pi/MagicMirror/node_modules/pm2/bin/pm2
                    /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
                    /home/pi/MagicMirror/node_modules/pm2/pm2
                    Which is the true one and one to use?
                      @plainbroke
                      Then use this:
                      /usr/local/bin/pm2
                      Regards, Chris.
                      plainbrokeP 1 Reply Last reply Reply Quote 1
                        @chrisfr1976
                        Thank you both for the help.
                        /usr/local/bin/pm2 restart mm
                        worked so I set it up to stop now and if (fingers crossed) works.
                        I am golden.
                        Wonder why I never had to use the full path before?
                        Maybe my pm2 path was /home/pi/pm2 before.
                        Doesn’t really matter as long as it works, I am a happy camper.
                        It works.
                        Thank you so much… I will mark this solved.
                        Well I would if I could… strange.
                        By the way " which pm2 " shows the path that I needed to use in crontab -e
                          @plainbroke awesome
                          i should have remembered the path problem
                            Did the new MM and or trixie change the way crontab works? Mine has stopped working since the update to 2.33. I tried again tonight and will see if the changes work or not… also my mm.json file quit working. Hind sight is 20/20 should have left well enough alone…
                              @plainbroke I do not know
                              Sorry, I have to ask, you DID use a new sd card, right?
                              What does /var/log/syslog say about the crontab execution
                              Did you use crontab -e
                              Or sudo crontab -e
                              1st is run as user who executed the crontab command
                              2nd is run as root
                                Using NVMe disk 256gb smallest I had on hand. 3 of them are exhibiting the same issues. I did try going back to Bookworm and I am still getthing a blank screen after a while. I ran npm run config:check it says all is good in the config.js ////
                                I am currently reloading from scratch.
                                Which OS is better for the 2.33 MM? 32 or 64 bit?
                                Wondering if I was using 32 bit and now the 64 bit is messing with me… So dang many things can mess with these little devices.
                                I only use crontab -e, should I try sudo crontab -e
                                  @plainbroke no, without sudo is best
                                  Maybe pm2 isn’t in the path when crontab fires
                                  Check the syslog for crontab errors
                                  32 bit is about to be trouble.
                                  The latest nodejs version, 24, has dropped builds for 32 bit
                                    Thanks for the info I almost pulled down 32 bit.
                                    It has been interesting to say the least going to trixie.
                                    Turns out my problem was a failed NVMe drive.
                                    I thought those things where supposed to last for a LONG long time…
                                    I did get crontab -e to work with trixie and MM 2.33 not a fun ride, but entertaining. I finally learned how to use bash to make batch style files…
                                    So not a complete loss of time…
                                      @plainbroke technology is SOOOO much fun! Simple, til it’s not!
                                      Thanks for the feedback. Others will ask, I’m sure they could use your help!
                                        Ok crontab -e worked last night to shutdown MM. So the pm2 stop all worked.
                                        BUT this morning the pm2 restart mm did nothing.
                                        I used find to get these:
                                        /usr/local/bin/pm2
                                        ANY idea on which one would work better.?
                                        Here is my current crontab -e
                                        # Turn off display at 9pm
                                        00 21 * * 0-6 /usr/local/bin/pm2 stop all >/dev/null >2&1
                                        # Turn on screen Monday - Friday at 6:45 am
                                        45 06 * * 1-5 /usr/local/bin/pm2 start mm >/dev/null >2&1
                                        # Turn on screen Saturday - Sunday at 7:30 am
                                        30 07 * * 6,0 /usr/local/bin/pm2 start mm >/dev/null >2&1
                                        S mumblebajM 3 Replies Last reply Reply Quote 0
                                          @plainbroke which one, if any , are in the path
                                          Are they all executable?
                                          ls -laF
                                          Will give you the permissions mask
                                          Are any of them links to another?
                                          What changed?
                                          /usr/local/bin/pm2
                                          Should be the one
                                            @plainbroke also look in /var/log/syslog
                                            To find the logging of the execute at the time it should fire
                                            • 2 / 3
