    pm2 doesnt work with crontab
    45 Posts 8 Posters 20.3k Views 6 Watching
      sdetweil @plainbroke
      @plainbroke no, without sudo is best
      Maybe pm2 isn’t in the path when crontab fires
      Check the syslog for crontab errors
      32 bit is about to be trouble.
      The latest nodejs version, 24, has dropped builds for 32 bit
      plainbrokeP 1 Reply Last reply
      • plainbrokeP
        plainbroke @sdetweil
        Thanks for the info I almost pulled down 32 bit.
        It has been interesting to say the least going to trixie.
        Turns out my problem was a failed NVMe drive.
        I thought those things where supposed to last for a LONG long time…
        I did get crontab -e to work with trixie and MM 2.33 not a fun ride, but entertaining. I finally learned how to use bash to make batch style files…
        So not a complete loss of time…
          @plainbroke technology is SOOOO much fun! Simple, til it’s not!
          Thanks for the feedback. Others will ask, I’m sure they could use your help!
          • plainbrokeP
            Ok crontab -e worked last night to shutdown MM. So the pm2 stop all worked.
            BUT this morning the pm2 restart mm did nothing.
            I used find to get these:
            /home/pi/MagicMirror/node_modules/.bin/pm2
            /home/pi/MagicMirror/node_modules/pm2
            /home/pi/MagicMirror/node_modules/pm2/bin/pm2
            /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
            /home/pi/MagicMirror/node_modules/pm2/pm2
            /usr/local/bin/pm2
            /usr/local/lib/node_modules/pm2
            /usr/local/lib/node_modules/pm2/bin/pm2
            /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
            /usr/local/lib/node_modules/pm2/pm2
            ANY idea on which one would work better.?
            Here is my current crontab -e
            # Turn off display at 9pm
            00 21 * * 0-6 /usr/local/bin/pm2 stop all >/dev/null >2&1
            # Turn on screen Monday - Friday at 6:45 am
            45 06 * * 1-5 /usr/local/bin/pm2 start mm >/dev/null >2&1
            # Turn on screen Saturday - Sunday at 7:30 am
            30 07 * * 6,0 /usr/local/bin/pm2 start mm >/dev/null >2&1
            S mumblebajM 3 Replies Last reply
              @plainbroke which one, if any , are in the path
              Are they all executable?
              ls -laF
              Will give you the permissions mask
              Are any of them links to another?
              What changed?
              /usr/local/bin/pm2
              Should be the one
                @plainbroke also look in /var/log/syslog
                To find the logging of the execute at the time it should fire
                • plainbrokeP
                  Weird, I do not have /var/log/syslog.
                  Even did a find for it nothing, popped up…
                  pi@Pixie:~ $ ls -laF
                  total 348
                  drwx------ 15 pi   pi     4096 Nov 10 15:36 ./
                  drwxr-xr-x  3 root root   4096 Sep 30 19:18 ../
                  -rw-------  1 pi   pi     9080 Nov 10 13:17 .bash_history
                  -rw-r--r--  1 pi   pi      220 Sep 30 19:06 .bash_logout
                  -rw-r--r--  1 pi   pi     3523 Sep 30 19:06 .bashrc
                  drwx------ 13 pi   pi     4096 Nov  7 18:22 .cache/
                  drwx------ 22 pi   pi     4096 Nov  8 12:57 .config/
                  drwx------  3 pi   pi     4096 Nov  7 17:49 .dbus/
                  drwxrwxr-x  2 pi   pi     4096 Sep 30 19:17 Desktop/
                  drwx------  2 pi   pi     4096 Nov  7 23:11 Documents/
                  -rw-rw-r--  1 pi   pi        0 Nov  7 20:00 .gitconfig
                  -rw-rw-r--  1 pi   pi       81 Nov  7 18:24 .gtkrc-2.0
                  -rw-rw-r--  1 pi   pi   222126 Oct 27 18:52 install.log
                  drwx------  4 pi   pi     4096 Sep 30 19:18 .local/
                  drwxrwxr-x 16 pi   pi     4096 Nov  8 12:54 MagicMirror/
                  -rwxrwxrwx  1 pi   pi      320 Jun 12  2022 mm.json*
                  -rwxrwxrwx  1 pi   pi       38 Jul 16  2023 mm.sh*
                  drwx------  4 pi   pi     4096 Nov  6 21:05 .mozilla/
                  drwxrwxr-x  4 pi   pi     4096 Oct 27 18:30 .npm/
                  drwx------  3 pi   pi     4096 Oct 27 18:52 .pki/
                  drwxrwxr-x  5 pi   pi     4096 Nov  9 17:24 .pm2/
                  -rw-r--r--  1 pi   pi      807 Sep 30 19:06 .profile
                  -rw-rw-r--  1 pi   pi       66 Oct 27 19:22 .selected_editor
                  drwxrwxr-x  4 pi   pi     4096 Nov 10 15:43 shared/
                  -rw-r--r--  1 pi   pi        0 Sep 30 19:18 .sudo_as_admin_successful
                  drwx------  3 pi   pi     4096 Nov  5 17:30 .vnc/
                  -rw-------  1 pi   pi       50 Nov  9 17:24 .Xauthority
                  -rw-------  1 pi   pi     8238 Nov  9 19:32 .xsession-errors
                  -rw-------  1 pi   pi     7945 Nov  9 17:24 .xsession-errors.old
                  • mumblebajM
                    mumblebaj Module Developer @plainbroke
                    @plainbroke Instead of piping the output to a blackhole, maybe pipe it to a logfile which you can interrogate to see why the pm2 start is not working?
                    evroomE 1 Reply Last reply
                    • evroomE
                      evroom @mumblebaj
                      About /var/log/syslog.
                      Debian does not use that anymore, already since a while.
                      As far as I understand it, you will need to get familiar with journalctl.
                      For cron jobs try this:
                      $ journalctl --since "1 hour ago" --unit cron.service
                      $ journalctl -f -u cron.service
                      Happy hunting.
                      MagicMirror version: 2.37.0
                      • plainbrokeP
                        plainbroke @evroom
                        @evroom,
                        I get that nothing is found, when I run either of your suggestions.
                        @mumblebaj
                        Explain piping, Please…
                        S evroomE mumblebajM 3 Replies Last reply
                          @plainbroke piping is a technique of stitching together multiple commands to accomplish a task
                          The vertical bar is called the pipe character
                          Which takes the output of the left side and presents it as input to the right side , so its like forming a pipe
                          When I want to find all the MagicMirror processes running in the background I do this
                          ps -ef
                          This give the processes and the command line used to start them
                          But is a lot of data
                          So I can filter that with grep , and I can pass in data on its stdin
                          ps -ef | grep -i MagicMirror
                          That gives just the rows of the process list with MagicMirror on them
                          But if I want to kill them I need the process id on each row
                          That’s the second value on each row
                          I can use the awk command to get that
                          ps -ef | grep -i MagicMirror | awk ‘{ print $2}’
                          Now I have the process ids and can issue the kill command with them
                          ps -ef | grep -i MagicMirror | awk ‘{ print $2}’ |  xargs sudo  kill -9
                          • evroomE
                            evroom @plainbroke
                            @plainbroke said in pm2 doesnt work with crontab:
                            @evroom,
                            The journalctl -f shows the current activities.
                            Simular to tail -f <filename>.
                            So when there are none, you will see none.
                            Use that when you know that a cron job is going to occur anytime soon.
                            The --since "1 hour ago" searches for activities in the last hour.
                            Change to, for example --since "24 hours ago" for activities in the last 24 hours.
                            When nothing comes out, then indeed nothing happened (during the time period you are searching in).
                            Other --since options:
                            "today"
                            "00:20"
                            "2025-11-12"
                            "2025-11-12 07:30:00"
                            • mumblebajM
                              @plainbroke Afternoon. What I was saying was that instead of sending your current output to a blackhole, >/dev/null >2&1, i meant sending it to a log file:
                              30 07 * * 6,0 /usr/local/bin/pm2 start mm >> /home/pi/mon.log 2>&1. This will send the output of the command /usr/local/bin/ pm2 start mm to a log file residing at /home/pi/mof.log. You can then interrogate this log file to see if there were any errors when the command was executed.
                              So, by pipe I meant redirect the output to somewhere.
                              • plainbrokeP
                                plainbroke
                                @mumblebaj
                                @evroom
                                Thank you all for the information.
                                I did not get to use it BUT I will save this information, so I do not have to ask again.
                                I woke up this morning and crontab -e had started my MM like old times… It also shutdown MM last night like it used to…
                                Tech is great when it does not try to give me a headache, trying to figure it out…
                                Thanks again guys for all your help.
                                I think I will close this as solved.
                                Just Jeff
                                  @plainbroke awesome! Thanks for the feedback
                                  • 2 / 3
