    pm2 doesnt work with crontab
    45 Posts 8 Posters 20.3k Views 6 Watching
      sdetweil @plainbroke
      @plainbroke awesome
      i should have remembered the path problem
      plainbrokeP 1 Reply Last reply
      • plainbrokeP
        plainbroke @sdetweil
        Did the new MM and or trixie change the way crontab works? Mine has stopped working since the update to 2.33. I tried again tonight and will see if the changes work or not… also my mm.json file quit working. Hind sight is 20/20 should have left well enough alone…
          @plainbroke I do not know
          Sorry, I have to ask, you DID use a new sd card, right?
          What does /var/log/syslog say about the crontab execution
          Did you use crontab -e
          Or sudo crontab -e
          1st is run as user who executed the crontab command
          2nd is run as root
          • plainbrokeP
            Using NVMe disk 256gb smallest I had on hand. 3 of them are exhibiting the same issues. I did try going back to Bookworm and I am still getthing a blank screen after a while. I ran npm run config:check it says all is good in the config.js ////
            I am currently reloading from scratch.
            Which OS is better for the 2.33 MM? 32 or 64 bit?
            Wondering if I was using 32 bit and now the 64 bit is messing with me… So dang many things can mess with these little devices.
            I only use crontab -e, should I try sudo crontab -e
              @plainbroke no, without sudo is best
              Maybe pm2 isn’t in the path when crontab fires
              Check the syslog for crontab errors
              32 bit is about to be trouble.
              The latest nodejs version, 24, has dropped builds for 32 bit
              • plainbrokeP
                Thanks for the info I almost pulled down 32 bit.
                It has been interesting to say the least going to trixie.
                Turns out my problem was a failed NVMe drive.
                I thought those things where supposed to last for a LONG long time…
                I did get crontab -e to work with trixie and MM 2.33 not a fun ride, but entertaining. I finally learned how to use bash to make batch style files…
                So not a complete loss of time…
                  @plainbroke technology is SOOOO much fun! Simple, til it’s not!
                  Thanks for the feedback. Others will ask, I’m sure they could use your help!
                  • plainbrokeP
                    Ok crontab -e worked last night to shutdown MM. So the pm2 stop all worked.
                    BUT this morning the pm2 restart mm did nothing.
                    I used find to get these:
                    /home/pi/MagicMirror/node_modules/.bin/pm2
                    /home/pi/MagicMirror/node_modules/pm2
                    /home/pi/MagicMirror/node_modules/pm2/bin/pm2
                    /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
                    /home/pi/MagicMirror/node_modules/pm2/pm2
                    /usr/local/bin/pm2
                    /usr/local/lib/node_modules/pm2
                    /usr/local/lib/node_modules/pm2/bin/pm2
                    /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
                    /usr/local/lib/node_modules/pm2/pm2
                    ANY idea on which one would work better.?
                    Here is my current crontab -e
                    # Turn off display at 9pm
                    00 21 * * 0-6 /usr/local/bin/pm2 stop all >/dev/null >2&1
                    # Turn on screen Monday - Friday at 6:45 am
                    45 06 * * 1-5 /usr/local/bin/pm2 start mm >/dev/null >2&1
                    # Turn on screen Saturday - Sunday at 7:30 am
                    30 07 * * 6,0 /usr/local/bin/pm2 start mm >/dev/null >2&1
                    S mumblebajM 3 Replies Last reply
                      @plainbroke which one, if any , are in the path
                      Are they all executable?
                      ls -laF
                      Will give you the permissions mask
                      Are any of them links to another?
                      What changed?
                      /usr/local/bin/pm2
                      Should be the one
                        @plainbroke also look in /var/log/syslog
                        To find the logging of the execute at the time it should fire
                        • plainbrokeP
                          Weird, I do not have /var/log/syslog.
                          Even did a find for it nothing, popped up…
                          pi@Pixie:~ $ ls -laF
                          total 348
                          drwx------ 15 pi   pi     4096 Nov 10 15:36 ./
                          drwxr-xr-x  3 root root   4096 Sep 30 19:18 ../
                          -rw-------  1 pi   pi     9080 Nov 10 13:17 .bash_history
                          -rw-r--r--  1 pi   pi      220 Sep 30 19:06 .bash_logout
                          -rw-r--r--  1 pi   pi     3523 Sep 30 19:06 .bashrc
                          drwx------ 13 pi   pi     4096 Nov  7 18:22 .cache/
                          drwx------ 22 pi   pi     4096 Nov  8 12:57 .config/
                          drwx------  3 pi   pi     4096 Nov  7 17:49 .dbus/
                          drwxrwxr-x  2 pi   pi     4096 Sep 30 19:17 Desktop/
                          drwx------  2 pi   pi     4096 Nov  7 23:11 Documents/
                          -rw-rw-r--  1 pi   pi        0 Nov  7 20:00 .gitconfig
                          -rw-rw-r--  1 pi   pi       81 Nov  7 18:24 .gtkrc-2.0
                          -rw-rw-r--  1 pi   pi   222126 Oct 27 18:52 install.log
                          drwx------  4 pi   pi     4096 Sep 30 19:18 .local/
                          drwxrwxr-x 16 pi   pi     4096 Nov  8 12:54 MagicMirror/
                          -rwxrwxrwx  1 pi   pi      320 Jun 12  2022 mm.json*
                          -rwxrwxrwx  1 pi   pi       38 Jul 16  2023 mm.sh*
                          drwx------  4 pi   pi     4096 Nov  6 21:05 .mozilla/
                          drwxrwxr-x  4 pi   pi     4096 Oct 27 18:30 .npm/
                          drwx------  3 pi   pi     4096 Oct 27 18:52 .pki/
                          drwxrwxr-x  5 pi   pi     4096 Nov  9 17:24 .pm2/
                          -rw-r--r--  1 pi   pi      807 Sep 30 19:06 .profile
                          -rw-rw-r--  1 pi   pi       66 Oct 27 19:22 .selected_editor
                          drwxrwxr-x  4 pi   pi     4096 Nov 10 15:43 shared/
                          -rw-r--r--  1 pi   pi        0 Sep 30 19:18 .sudo_as_admin_successful
                          drwx------  3 pi   pi     4096 Nov  5 17:30 .vnc/
                          -rw-------  1 pi   pi       50 Nov  9 17:24 .Xauthority
                          -rw-------  1 pi   pi     8238 Nov  9 19:32 .xsession-errors
                          -rw-------  1 pi   pi     7945 Nov  9 17:24 .xsession-errors.old
                          • mumblebajM
                            mumblebaj Module Developer @plainbroke
                            @plainbroke Instead of piping the output to a blackhole, maybe pipe it to a logfile which you can interrogate to see why the pm2 start is not working?
                            evroomE 1 Reply Last reply
                            • evroomE
                              evroom @mumblebaj
                              About /var/log/syslog.
                              Debian does not use that anymore, already since a while.
                              As far as I understand it, you will need to get familiar with journalctl.
                              For cron jobs try this:
                              $ journalctl --since "1 hour ago" --unit cron.service
                              $ journalctl -f -u cron.service
                              Happy hunting.
                              MagicMirror version: 2.37.0
                              • plainbrokeP
                                plainbroke @evroom
                                @evroom,
                                I get that nothing is found, when I run either of your suggestions.
                                @mumblebaj
                                Explain piping, Please…
                                S evroomE mumblebajM 3 Replies Last reply
                                  @plainbroke piping is a technique of stitching together multiple commands to accomplish a task
                                  The vertical bar is called the pipe character
                                  Which takes the output of the left side and presents it as input to the right side , so its like forming a pipe
                                  When I want to find all the MagicMirror processes running in the background I do this
                                  ps -ef
                                  This give the processes and the command line used to start them
                                  But is a lot of data
                                  So I can filter that with grep , and I can pass in data on its stdin
                                  ps -ef | grep -i MagicMirror
                                  That gives just the rows of the process list with MagicMirror on them
                                  But if I want to kill them I need the process id on each row
                                  That’s the second value on each row
                                  I can use the awk command to get that
                                  ps -ef | grep -i MagicMirror | awk ‘{ print $2}’
                                  Now I have the process ids and can issue the kill command with them
                                  ps -ef | grep -i MagicMirror | awk ‘{ print $2}’ |  xargs sudo  kill -9
                                  • evroomE
                                    evroom @plainbroke
                                    @plainbroke said in pm2 doesnt work with crontab:
                                    @evroom,
                                    The journalctl -f shows the current activities.
                                    Simular to tail -f <filename>.
                                    So when there are none, you will see none.
                                    Use that when you know that a cron job is going to occur anytime soon.
                                    The --since "1 hour ago" searches for activities in the last hour.
                                    Change to, for example --since "24 hours ago" for activities in the last 24 hours.
                                    When nothing comes out, then indeed nothing happened (during the time period you are searching in).
                                    Other --since options:
                                    "today"
                                    "00:20"
                                    "2025-11-12"
                                    "2025-11-12 07:30:00"
                                    • mumblebajM
                                      @plainbroke Afternoon. What I was saying was that instead of sending your current output to a blackhole, >/dev/null >2&1, i meant sending it to a log file:
                                      30 07 * * 6,0 /usr/local/bin/pm2 start mm >> /home/pi/mon.log 2>&1. This will send the output of the command /usr/local/bin/ pm2 start mm to a log file residing at /home/pi/mof.log. You can then interrogate this log file to see if there were any errors when the command was executed.
                                      So, by pipe I meant redirect the output to somewhere.
                                      • plainbrokeP
                                        plainbroke
                                        @mumblebaj
                                        @evroom
                                        Thank you all for the information.
                                        I did not get to use it BUT I will save this information, so I do not have to ask again.
                                        I woke up this morning and crontab -e had started my MM like old times… It also shutdown MM last night like it used to…
                                        Tech is great when it does not try to give me a headache, trying to figure it out…
                                        Thanks again guys for all your help.
                                        I think I will close this as solved.
                                        Just Jeff
                                          @plainbroke awesome! Thanks for the feedback
                                          • 2 / 3
