    pm2 doesnt work with crontab
    45 Posts 8 Posters 16.4k Views 6 Watching
      sdetweil @plainbroke
      @plainbroke piping is a technique of stitching together multiple commands to accomplish a task
      The vertical bar is called the pipe character
      Which takes the output of the left side and presents it as input to the right side , so its like forming a pipe
      When I want to find all the MagicMirror processes running in the background I do this
      ps -ef
      This give the processes and the command line used to start them
      But is a lot of data
      So I can filter that with grep , and I can pass in data on its stdin
      ps -ef | grep -i MagicMirror
      That gives just the rows of the process list with MagicMirror on them
      But if I want to kill them I need the process id on each row
      That’s the second value on each row
      I can use the awk command to get that
      ps -ef | grep -i MagicMirror | awk ‘{ print $2}’
      Now I have the process ids and can issue the kill command with them
      ps -ef | grep -i MagicMirror | awk ‘{ print $2}’ |  xargs sudo  kill -9
      • evroomE Offline
        evroom @plainbroke
        @plainbroke said in pm2 doesnt work with crontab:
        @evroom,
        I get that nothing is found, when I run either of your suggestions.
        The journalctl -f shows the current activities.
        Simular to tail -f <filename>.
        So when there are none, you will see none.
        Use that when you know that a cron job is going to occur anytime soon.
        The --since "1 hour ago" searches for activities in the last hour.
        Change to, for example --since "24 hours ago" for activities in the last 24 hours.
        When nothing comes out, then indeed nothing happened (during the time period you are searching in).
        Other --since options:
        "today"
        "00:20"
        "2025-11-12"
        "2025-11-12 07:30:00"
        MagicMirror version: 2.35.0
        Test environment:
        MagicMirror version: 2.36.0-develop
        • mumblebajM Offline
          mumblebaj Module Developer @plainbroke
          @plainbroke Afternoon. What I was saying was that instead of sending your current output to a blackhole, >/dev/null >2&1, i meant sending it to a log file:
          30 07 * * 6,0 /usr/local/bin/pm2 start mm >> /home/pi/mon.log 2>&1. This will send the output of the command /usr/local/bin/ pm2 start mm to a log file residing at /home/pi/mof.log. You can then interrogate this log file to see if there were any errors when the command was executed.
          So, by pipe I meant redirect the output to somewhere.
          • plainbrokeP Offline
            plainbroke
            @mumblebaj
            @evroom
            Thank you all for the information.
            I did not get to use it BUT I will save this information, so I do not have to ask again.
            I woke up this morning and crontab -e had started my MM like old times… It also shutdown MM last night like it used to…
            Tech is great when it does not try to give me a headache, trying to figure it out…
            Thanks again guys for all your help.
            I think I will close this as solved.
            Just Jeff
              @plainbroke awesome! Thanks for the feedback
              • 3 / 3
