    Some help for those on windows machines
    tutorial
    3 Posts 2 Posters 1.2k Views 2 Watching
    • michaeldunM
      michaeldun
      This is more of a tutorial to help.
      When I was setting my MM on my computer, I did run into an issue. Which says the following:
      > magicmirror@2.14.0 start C:\Users\fredb\Downloads\MagicMirror
      'DISPLAY' is not recognized as an internal or external command,
      operable program or batch file.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.14.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.14.0 start script.
      I sorted this with the following
      editing the package.json, change the “start” line and removing all the DISPLAY stuff so it starts “./node_modules”
      Then you have to do
      cd MagicMirror
      cd vendor
      npm install
      cd ..
      cd fonts
      npm install
      cd ..
      Then you can do npm start.
      Thanks Sam on discord for helping me.
      Reply Quote 1
        sdetweil @michaeldun
        @michaeldun said in Some help for those on windows machines:
        Sam on discord
        thats me… my signature here is Sam
        michaeldunM 1 Reply Last reply
        Reply Quote 1
        • michaeldunM
          michaeldun @sdetweil
          @sdetweil Thanks! Just didn’t know which one was you, too many @ sams
          Michael
