    ./node_modules/.bin/electron js / electron.js Problem
    23 Posts 2 Posters 6.1k Views 2 Watching
      sdetweil @youssef
      @youssef ok, remove the MM folder and redo the install script… should set it up properly now…
      for some reason the electron test for this OS returns 32 bit, but the OS says 64…
      weird…
      • Y Offline
        youssef
        @sdetweil said in ./node_modules/.bin/electron js / electron.js Problem:
        weir
        Hello,
        it’s work, thank you for your support can you please explain to me what was the isssue.
          sdetweil @youssef
          @youssef for some reason the electron installer (not our code) has decided this is a 32 bit machine. and there is no 32bit electron available for intel.
          I think I will open an issue over there.
          my previous install worked fine…
