    MMM-Pages - WeatherModules: LockStrings active
    5 Posts 2 Posters 1.3k Views 2 Watching
    • O
      OberfragGER
      i have the MagicMirror running with various Modules.
      When the Mirror loads, the WeatherModules are shown correctly. But when “finished” loading after 2-3 seconds, the Modules
      MMM-OpenmapWeather and
      weatherforecast are not shown!
      Development console means:
      Will not show MMM-OpenmapWeather. LockStrings active: module_11_MMM-OpenmapWeather
      Will not show weatherforecast. LockStrings active: module_13_weatherforecast
      The strange thing- it was working, i added one module changed the config.js, revert the change and then the Modules are not shown.
      Do you have any idea to fix that.
      O 1 Reply Last reply
      • O
        OberfragGER @OberfragGER
        @oberfragger
        This one fixed itself… i dont have any clue why.
        • O
          @oberfragger Somehow…something needs to be changed…
          I needs to run a few minutes an then its working.
          https://forum.magicmirror.builders/topic/10486/why-does-currentweather-use-lockstring
            sdetweil @OberfragGER
            @oberfragger the two.modules will be replaced in the next release… current and forecast
            they are available now in the develop branch. coming to production April 1
            • O
              OberfragGER @sdetweil
              @sdetweil Thanks for you fast reply.
              Im a bit new to MM2 so i will learn how to uptade modules and MM2 itself.
              I inspected this and got a similar answer by myself… this modules are “the culprit”, not MMM-Page ;)
              In the meantime i found a good replacement for OpenWeatherMap. OpenWeatherForecast- very nice. I will play a bit around…
