    Alignmend of modules
    11 Posts 5 Posters 5.3k Views 5 Watching
    • C Offline
      codac
      As I have the default calendar plugin, which needs a width of 475px, the upper modules currentweather, weatherforecast and MMM-DWD-WarnWeather are not really right-aligned. As you can see on the screenshot, I would like to keep the module on the right border of the frame. For the DWD-WarnWeather module, the module itself is placed correct, but the content is not right aligned.
      What Do I need to do in order to fix that?
      • karsten13K Offline
        karsten13 @codac
        @codac all these modules have the same position top_right?
        For the warnings module you could use custom.css and overwrite the text-align: left; in the module css with text-align: right;
        You can also play with css in the browser, e.g. see this thread.
        • C Offline
          codac
          @karsten13 correct they are all top_right. Your suggestion worked:
          .MMM-DWD-WarnWeather .status {
              font-family: "SFPro";
              text-align: right;
          Your hint with playing with css in my browser helped to figure out that currentweather and weatherforecast behave like this because of a max-width of 325 that I already had set in the custom.css, as where the calendar has 475px.
            MajorC Project Sponsor @codac
            @codac I think you have to add
            .MMM-DWD-WarnWeather .description {
                text-align: right;
              I have a similar problem.
              I would like to have the yellow icon closer to the right in the module: ‘MMM-DWD-WarnWeather’.
              And I would like to get rid of the space on the right in the module: “MMM-DWD-Pollen”.
              C S 2 Replies Last reply Reply Quote 0
              • C Offline
                codac @MajorC
                @majorc The question with the MMM-DWD-WarnWeather module I can answer. Was a bit tricky to find out, but what works for me is to set the follwing into the custom.css:
                .MMM-DWD-WarnWeather .warning {
                    float: right;
                  @codac said in Alignmend of modules:
                  float: right;
                  Thanks, that is a good one!
                    sdetweil @MajorC
                    @majorc u could try the same float-right for the pollen module
                    u may need to look in the developers window, elements tab to see the class used
                    ctrl-shift-i, select the elements tab, expand the nav tree in the left column to locate the module (top, top-right…)
                    set the module background to blue, to see the whole thing
                    and then add styles to the content
                    see how to use the elements tab info here
                    https://forum.magicmirror.builders/topic/14782/make-a-remove-header-space-or-overlap-two-modules/5
                    • C Offline
                      CarstenD @sdetweil
                      @sdetweil for MMM-DWD-Pollen you can change the following classes in CSS:
                      tab-center
                      pollen-low
                      pollen-low-medium
                      pollen-medium
                      pollen-mediumhigh
                      pollen-high
                      pollen-nodata
                      and just make
                      text-align: right
                      That should do the trick. Float will not work - it pushes everything to the right w/o spacing.
                      I am still thinking how one can save the space on the right side but I am not an CSS / HTML expert.
                        sdetweil @CarstenD
                        @carstend said in Alignmend of modules:
                        me neither… i hate working on the UI
                          MajorC Project Sponsor @CarstenD
                          @carstend I added the question to the DWD-Pollen thread, but no respond so far.
                          https://forum.magicmirror.builders/topic/12247/mmm-dwd-pollen/19?_=1616656403635
                          text-align: right
                          will move the text, so it is not centered anymore. But the goal is, to get rid of the space on the right side.
                          Update:
                          I now use:
                          .MMM-DWD-Pollen table {
                          	margin-left: auto;
                          	margin-right: -40px;
                          Not sure if this is a good way, but it works for me at the moment.
