    Date in the calendar module is in the wrong format. MM/DD/YY instead of DD/MM/YY
    2 Posts 2 Posters 908 Views 2 Watching
      sander023
      The calendar module displays the date of my calendar entries as MM/DD/YY but I want to change it into DD/MM/YY or anything used in europe.
      Things I tried:
      • I looked at the documentation (https://docs.magicmirror.builders/modules/calendar.html) and read https://momentjs.com/docs/#/parsing/string-format/.
      • In the config.js I tried the following code but it does not seem to change anything:
      config:{
          dateFormat: "DD MM YY",
      • I also tried:
      config:{
          fullDayEventDateFormat: "DD MM YY",
      Is there something I’m missing because I cannot figure out how to get it working.
      Thanks in advance for the help!
        sdetweil @sander023
        @sander023 I put your post back, cause I want to reply for others…
        in this case, u also need timeFormat:‘absolute’,
        				dateFormat: "DD/MM/YY",
        				timeFormat:'absolute',
        				fullDayEventDateFormat:"DD/MM/YY",
