    Unable to install dependencies
    4 Posts 3 Posters 1.6k Views 3 Watching
    • L Offline
      luke1
      Hi, i have a raspberry pi 3 with raspian version 10 “buster”. I repeatedly get the same error when I try to install MM2. I use this script:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      This is the log:
      1443 verbose type system
      1444 verbose stack FetchError: Invalid response body while trying to fetch https://registry.npmjs.org/color-convert: Integrity verification failed for sha512-exjiN94u2EORAE/AeYWCUz/D3vWlG2W2nMKEvSyaqbaNAuQ6ApnzNngc/M/M8Yw9WU65bhJDn1dPK/vz0/n2WQ== (/home/pi/.npm/_cacache/content-v2/sha512/7b/18/e237de2ed84391004fc0798582533fc3def5a51b65b69cc284bd2c9aa9b68d02e43a0299f336781cfccfccf18c3d594eb96e12439f574f2bfbf3d3f9f659)
      1444 verbose stack at Readable.body.on.err (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/body.js:195:14)
      1444 verbose stack at Readable.emit (events.js:198:13)
      1444 verbose stack at cacache.get.byDigest.then.err (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/cache.js:92:30)
      1444 verbose stack at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      1444 verbose stack at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
      1444 verbose stack at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
      1444 verbose stack at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
      1444 verbose stack at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:695:18)
      1444 verbose stack at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
      1444 verbose stack at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
      1444 verbose stack at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
      1444 verbose stack at Immediate.Async.drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
      1444 verbose stack at runCallback (timers.js:705:18)
      1444 verbose stack at tryOnImmediate (timers.js:676:5)
      1444 verbose stack at processImmediate (timers.js:658:5)
      1445 verbose cwd /home/pi/MagicMirror
      1446 verbose Linux 5.10.17-v7+
      1447 verbose argv “/usr/bin/node” “/usr/bin/npm” “install” “–only=prod”
      1448 verbose node v10.24.0
      1449 verbose npm v6.14.11
      1450 error code EINTEGRITY
      1451 error errno EINTEGRITY
      1452 error Invalid response body while trying to fetch https://registry.npmjs.org/color-convert: Integrity verification failed for sha512-exjiN94u2EORAE/AeYWCUz/D3vWlG2W2nMKEvSyaqbaNAuQ6ApnzNngc/M/M8Yw9WU65bhJDn1dPK/vz0/n2WQ== (/home/pi/.npm/_cacache/content-v2/sha512/7b/18/e237de2ed84391004fc0798582533fc3def5a51b65b69cc284bd2c9aa9b68d02e43a0299f336781cfccfccf18c3d594eb96e12439f574f2bfbf3d3f9f659)
      1453 verbose exit [ 1, true ]
      Thanks for your help:)
      lavolp3L S 2 Replies Last reply Reply Quote 0
      • lavolp3L Offline
        lavolp3 Module Developer @luke1
        @luke1 Not ure if it helps but try to update node and npm
        E.g. using the n module
        npm install -g npm@latest
        npm cache clean -f
        npm install -g n
        n stable
        You may need to use sudo for all of these operations.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @luke1
          @luke1 I think the npm cache is corrupt do
          cd ~
          sudo rm -rf .npm
          then restart the install script. it will installer upgrade node and npm if needed
          • L Offline
            luke1
            @lavolp3 @sdetweil Thanks a lot! it works now :)
