    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 20.1k Views 10 Watching
    • U Offline
      ulster
      MagicMirror² v2.15.0 is available, it seems not to work.
      I made de update and its off.
      Only opens electron
      Can someone help please?
      S unfriendlydeviceU 2 Replies Last reply Reply Quote 0
        sdetweil @ulster
        @ulster u did a git pull and then and npm install, yes?
        from the MM folder
        U 1 Reply Last reply Reply Quote 0
        • unfriendlydeviceU Offline
          unfriendlydevice @ulster
          @ulster If you’re using MMM-GoogleAssistant I found I had to disable this otherwise I was only seeing a black screen following updating to v2.15.0
            sdetweil @unfriendlydevice
            @unfriendlydevice u have to run electron-rebuild in the google assistant and pir folders
            unfriendlydeviceU 1 Reply Last reply Reply Quote 1
            • U Offline
              ulster @sdetweil
              @sdetweil said in MagicMirror² v2.15.0 is available don't work.:
              npm install
              yes
                sdetweil @ulster
                @ulster ok, so what to the message look like (in the window where us start MM, with npm start
                or if you use pm2,
                the pm2 logs --lines =???
                ??? is a number, default 15
                • U Offline
                  ulster @sdetweil
                  @unfriendlydevice
                  at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                  at Module._compile (internal/modules/cjs/loader.js:1152:30)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10) {
                  code: ‘MODULE_NOT_FOUND’,
                  requireStack: [
                  ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js’,
                  ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js’,
                  ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js’,
                  ‘/home/pi/MagicMirror/js/app.js’,
                  ‘/home/pi/MagicMirror/js/electron.js’,
                  ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                  undefined
                  Yes, a black screen
                    sdetweil @ulster
                    @ulster so, you need to do
                    cd ~/MagicMirror
                    npm install electron-rebuild
                    cd ~/MagicMirror/modules/MMM-GoogleAssistant
                    ~/MagicMirror/node_modules/.bin/electron-rebuild
                    note the . (dot) in front of bin on the last command
                    • U Offline
                      ulster @sdetweil
                      sorry, still not work.
                      01.04.2021 20:54.05.668] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v11.3-linux-arm/snowboy.node’
                      Require stack:
                      • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
                      • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js
                      • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
                      • /home/pi/MagicMirror/js/app.js
                      • /home/pi/MagicMirror/js/electron.js
                      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                        sdetweil @ulster
                        @ulster ok, lets try his tool
                        from the module folder do
                        npm run  rebuild
                        I have installed on 2.15 and it works…
                        • U Offline
                          ulster @sdetweil
                          npm run rebuild
                          now the problem seems to be in mmm assistant2display
                          01.04.2021 21:21.49.886] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/epoll/build/Release/epoll.node’
                          was compiled against a different Node.js version using
                          NODE_MODULE_VERSION 76. This version of Node.js requires
                          NODE_MODULE_VERSION 85. Please try re-compiling or re-installing
                          the module (for instance, using npm rebuild or npm install).
                            sdetweil @ulster
                            @ulster so, do the npm run rebuild in the Assistant2Display folder epoll is a bugger
                            • U Offline
                              ulster @sdetweil
                              @sdetweil !
                              thank you
                              W 1 Reply Last reply Reply Quote 1
                              • W Offline
                                Wenike @ulster
                                @ulster Just for others running into the same issue, MMM-CalendarExt2 uses the now-deprecated valid-url, so it also throws the black screen on MM launch. I’m not nearly good enough at any coding to attempt a fix though.
                                  sdetweil @Wenike
                                  @wenike deprecated doesn’t mean no longer works… just means you “shouldn’t use it for NEW development”
                                  SO, if its not loaded, YOU can still load it…
                                  npm install valid-url
                                  in whatever module needs it
                                  W D 2 Replies Last reply Reply Quote 2
                                  • W Offline
                                    Wenike @sdetweil
                                    @sdetweil THANKS!
                                    • StoffbeuteluweS Offline
                                      Stoffbeuteluwe Project Sponsor
                                      Hi i have also a black screen… I used the script
                                      > magicmirror@2.15.0 start /Users/patrickhahn/MagicMirror
                                      [02.04.2021 07:20.18.249] [LOG]   Starting MagicMirror: v2.15.0
                                      [02.04.2021 07:20.18.252] [LOG]   Loading config ...
                                      [02.04.2021 07:20.18.257] [LOG]   Loading module helpers ...
                                      [02.04.2021 07:20.18.258] [LOG]   No helper found for module: alert.
                                      [02.04.2021 07:20.18.386] [LOG]   Initializing new module helper ...
                                      [02.04.2021 07:20.18.386] [LOG]   Module helper loaded: MMM-Remote-Control
                                      [02.04.2021 07:20.18.483] [LOG]   Initializing new module helper ...
                                      [02.04.2021 07:20.18.483] [LOG]   Module helper loaded: updatenotification
                                      [02.04.2021 07:20.18.576] [LOG]   No helper found for module: MMM-Snow.
                                      [02.04.2021 07:20.18.577] [LOG]   No helper found for module: MMM-WordClock.
                                      [02.04.2021 07:20.18.624] [LOG]   No helper found for module: clock.
                                      [02.04.2021 07:20.18.662] [LOG]   No helper found for module: calendar_monthly.
                                      [02.04.2021 07:20.21.072] [LOG]   Initializing new module helper ...
                                      [02.04.2021 07:20.21.073] [LOG]   Module helper loaded: calendar
                                      [02.04.2021 07:20.21.107] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
                                      Require stack:
                                      - /Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/node_helper.js
                                      - /Users/patrickhahn/MagicMirror/js/app.js
                                      - /Users/patrickhahn/MagicMirror/js/electron.js
                                      - /Users/patrickhahn/MagicMirror/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
                                      [02.04.2021 07:20.21.108] [LOG]   Loading module helpers ...
                                      [02.04.2021 07:20.21.108] [LOG]   No helper found for module: alert.
                                      [02.04.2021 07:20.21.109] [LOG]   Initializing new module helper ...
                                      [02.04.2021 07:20.21.109] [LOG]   Module helper loaded: MMM-Remote-Control
                                      [02.04.2021 07:20.21.109] [LOG]   Module helper loaded: updatenotification
                                      [02.04.2021 07:20.21.109] [LOG]   No helper found for module: MMM-Snow.
                                      [02.04.2021 07:20.21.110] [LOG]   No helper found for module: MMM-WordClock.
                                      [02.04.2021 07:20.21.110] [LOG]   No helper found for module: clock.
                                      [02.04.2021 07:20.21.110] [LOG]   No helper found for module: calendar_monthly.
                                      [02.04.2021 07:20.21.110] [LOG]   Initializing new module helper ...
                                      [02.04.2021 07:20.21.111] [LOG]   Module helper loaded: calendar
                                      [02.04.2021 07:20.21.111] [ERROR] App threw an error during load
                                      [02.04.2021 07:20.21.112] [ERROR] Error: Cannot find module 'valid-url'
                                      Require stack:
                                          at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                                          at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                                          at Function.Module._resolveFilename (/Users/patrickhahn/MagicMirror/node_modules/module-alias/index.js:49:29)
                                          at Module._load (internal/modules/cjs/loader.js:848:27)
                                          at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
                                          at Module.require (internal/modules/cjs/loader.js:1032:19)
                                          at require (internal/modules/cjs/helpers.js:72:18)
                                          at Object.<anonymous> (/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/node_helper.js:9:16)
                                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                                      [02.04.2021 07:20.21.112] [ERROR] Whoops! There was an uncaught exception...
                                      [02.04.2021 07:20.21.115] [ERROR] Error: Cannot find module 'valid-url'
                                      Require stack:
                                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10) {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: [
                                          '/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
                                          '/Users/patrickhahn/MagicMirror/js/app.js',
                                          '/Users/patrickhahn/MagicMirror/js/electron.js',
                                          '/Users/patrickhahn/MagicMirror/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js',
                                          undefined
                                      [02.04.2021 07:20.21.116] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      [02.04.2021 07:20.21.116] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      [02.04.2021 07:20.23.546] [LOG]   Launching application.
                                        sdetweil @Stoffbeuteluwe
                                        @stoffbeuteluwe valid-url was removed from the mm package. do
                                        in the mm folder
                                          Stoffbeuteluwe Project Sponsor @sdetweil
                                          @sdetweil Hi Sam that works… thank you … weatherforcast shows wrong time for the first 3 lines (night instead of day)Bildschirmfoto 2021-04-02 um 19.22.08.png
                                            @stoffbeuteluwe forecast and currentweather have been replaced by new code, old code is still there for a while…
                                            • 1 / 3
